Allnic L6500 - shiny and new
jac.revival
6
8
5
72
Edmonton, Alberta, Canada
Ketcham mentioned, in his thread about Corby's grand opening in early November, a very little tidbit about the L6500 linestage. Dave Beetles, Hammertone Audio, (N.A. Allnic distributor and long time audio pal) was kind enough to send me a few pictures of said L6500 - that I would care to share.
I understand that the units are shipping now (we spoke about 'shipping' - holy schmokes has that ever gone up a bunch!) and that the introductory price point might be $6900usd.
Very nice.
I like the new Allnic H-6500 a lot :)
In my set up, the H-6500 does play very nice and more close to my favorite H-7000v than expected.
Similar to H-7000v I prefer a Kron rectifier in the PSU. In Europe the prices are between 8k an 10k eur, depending on the local distributor.
Here some pics of my unit:
IMG_6779.jpgIMG_6781.jpgIMG_6783.jpgIMG_6786.jpgIMG_6785.jpgIMG_6780.jpgIMG_6789.jpgIMG_6784.jpg
View attachment 84796View attachment 84797View attachment 84798View attachment 84799View attachment 84800View attachment 84801View attachment 84802View attachment 84803
Any impedance adjustment for MM.
not at my H-6500
but maybe you can order a customized H-6500.
This function is also not standard on H-7000 or H-7000v, but can be ordered as additional feature.
not at my H-6500
Thankyou, I have this on my 3000v, I guess he dropped this on the newer models then
Hi Shakti
Can you expand a bit on your comment that it "plays more close to the H7000v than expected" please? I can see it only has one MM and one MC input & doesn't have the curve flexibility of the 7000V , but where are the differences in sound? After all, its less than half the price.
Thanks
Hi Shakti
Can you expand a bit on your comment that it "plays more close to the H7000v than expected" please? I can see it only has one MM and one MC input but where are the differences in sound? After all, its less than half the price.
Thanks
as all current Allnic Phono stages the H-6500 has 2MM and 2 MC input. All phono stages do have the same copper Step Up for MC.
Listening to H-5500, H- 6500 and H-7000 demonstrates to family sound of Allnic.
Engaging, transparent, fluent, well balanced, little soft and less transparent compared to some BIC solid state (CHP, Boulder 2008).
Realizing the price point, the H-6500 should be closer to H-5500 and and a big step to reach the H-7000 level.
But H-6500 (in my et up) is more close to H-7000 level than to H-5500 (using Kron Recti in H-6500 and H-7000)
Allnic performance in climbing up the product range is improving in terms of resolution, over all- and micro dynamics, room, emotions...
At least, with H-7000 you are closer to the real music event in front of you as listening to the H-5500.
Reactions: Chop
Thanks for that Shakti, appreciate it. In your experience is there much difference in the soundstaging (I mean the 3D nature of the sound) between the H6500 and the H7000?
As sound staging is mainly driven by low bass performance, the H-7000 is the better one with a fair distance to the much cheaper H-6500. If soundstage is your main scope, the H-7000 is the phono stage to go. H-6500 can compete in many criteria, but the lowest register is definitely better with H-7000 ( as least in my setup)
Reactions: Chop
