Advice for a new sub
Mar 16, 2017
2
Hi first time poster...
I am looking to add a sub to my speaker and amp setup I have currently, and hoping for advice on which to look into more. Im looking for a little extra boom at the lower end for my movies while not sacrificing quality while listening to my vinyls. My room is about 13x20.
Current setup is TT>Rega Brio>Dynaudio Emit
Trying to decide between:
REL T5
SVS SB-2000
Velodyne impact 12"
BK xxls400
Are there others I should look at? Which are the favorites of the above? Anything else I'm missing? I need something that will be ok with my Rega (power, speaker line, etc)
Thanks
treitz3
Super Moderator
#3
Rythmik subs (servo/sealed) would be a great contender for your consideration. I'll also be installing two in my room within the next couple of months. I just so happen to be a big fan of servo subs.
Oh, my manners. Please allow me to offer you a very warm welcome to the What's Best Forum.
Tom
DaveyF
Active Member
Aug 1, 2010
5,633
4
38
La Jolla, Calif USA
#7
I own a Rel T5, it's an excellent sub...particularly if you upgrade the connecting cable. However, I think in a room of your size, matching the size of the sub and its ability is crucial. The Rel T5 would be a little too small for that space, imho. Better to consider one of the slightly larger Rel models.
audioguy
Apr 21, 2010
2,723
5
38
#9
Either of these (Click on the sub names to go to the Seaton Forum to see them):
Seaton F18's I have 4 of these (not 6 as in the photo), 2 in each of the front two corners, all driven by a single 4000 watt integrated amp in a Master/Slave configuration. Other amp/speaker configurations are possible.
Seaton SubMersive. I have two of these, also driven by a single 4000 watt amp in a Master/Slave configuration. These are dual opposed 15's
I won't say they are the best subs available but having heard (and owned) many (including some mentioned above), they are the best I have ever heard.
Oct 13, 2012
81
#10
I had a SVS SB13 Ultra, SVS SB16 Ultra, SVS PB200, Martin Logan Depth I, and JL Audio F110 v2. In the context of my system/room the F110 v2 has tight articulate bass and the most musical bass to my ears. In my opinion its not even close.
  • Founded in 2010 What's Best Forum invites intelligent and courteous people of all interests and backgrounds to describe and discuss the best of everything. From beginners to life-long hobbyists to industry professionals we enjoy learning about new things and meeting new people and participating in spirited debates.
