Adding sub: should I add single or dual subs?
murphys33
112
10
258
Hi guys,
I am contemplating adding subwoofers. Should I go with a dual or single sub? Intention is to crossover at 36hz where my speakers tail off. Looking at single rythmik E15 or dual rythmik f12.
RogerD
3,734
318
565
BiggestLittleCity
Depending on your room size,have you considered 2 subs,left and right. I have that config in my system and it works out wonderfully.
GaryProtein
2,542
31
385
NY
Go with the two f12 subs.
The room response will be smoother.
Folsom
6,020
1,486
520
Eastern WA
Dual. I modify Rhythmic amplifiers (for people) and they're a great option; better than most subwoofers at any price level.
JackD201
1,420
1,820
Manila, Philippines
es347
35
970
Midwest fly over state..
..dual
murphys33
112
10
258
What other brands would you suggest I consider?
audioguy
73
1,635
REL; JL Audio; Seaton Sound; I am sure there are more but I have heard each of those paired with very high end speakers (Wilson, Magico, Martin Logan, etc) and each was incredible.
That said, proper integration with your mains (room position, delay and trim settings, EQ, etc) will ultimately determine if you are pleased with the sound. Any of those mentioned with proper integration will work spectacularly.
Rodney Gold
983
11
18
Cape Town South Africa
Folsom
6,020
1,486
520
Eastern WA
Just what do you do to them to modify them !
I give them what they need to become something that has few if any peers. Here's a link. For many it'll be hard to understand why the modifications are so substantial, but they are, and have proven themselves.
15,962
13,231
2,665
15,962
13,231
2,665
+1
Mark Seaton
WBF Technical Expert (Speaker & Acoustics)
May 21, 2010
381
141
390
47
Chicago, IL
www.seatonsound.net
Hi guys,
You will want an ability to implement a crossover in the 30-50Hz range, with the frequency depending on how your Giya G3's are interacting with their placement in the room, and the final balance you prefer. Do you have some pictures of the room and where you could place the subwoofers? In more than a few stereo systems where I've added subs we have been able to move the speakers to locations where you get even better imaging and soundstage in trade for less bass reinforcement, so that might be something to consider or experiment with as well.
murphys33
112
10
258
Thanks all - decided to add 2 F12.
infinitely baffled
1,259
387
340
Scotland
