How To Videos - Room Correction, Speaker Correction, Digital Crossover
Nyal Mellor
590
4
330
SF Bay Area, CA, USA
Some videos I made this week showing how to use the DEQX calibration software for room correction, speaker correction and digital crossover...
More available on my YouTube channel: http://www.youtube.com/user/AcousticFrontiers
Happy holidays! Is it xmas yet!?
Nyal Mellor
590
4
330
Thanks for looking. DEQX is so cool!
almikel
6
Thanks Nyal,
one question - you gave the correction filter a name - test speaker correction (or similar), but then when configuring the speaker you picked correction set 6 - ie it had no relationship to the name you gave it.
Great video by the way - I'll seek out your others.
I find that because you don't generate new speaker measurements/corrections that often, I need to re-learn how to do it each time (often finding new tweaks along the way).
An example was it took me 10 minutes recently to work out how to determine how steep the crossovers were in the current setup - you don't seem to be able to do it from the control panel - you need to do it from the configuration panel, and then you need to make sure you pick the correct DEQX configuration (ie the one currently configured)
Amazing bit of kit all the same
Mike
