Listening with your eyes? How to read graphs.
amirm
Banned
Apr 2, 2010
15,813
37
Seattle, WA
Julf
613
Amsterdam, The Netherlands
I agree about the annoying limitation on length of music that can be sampled. But the fact that spectral analysis can be confusing if you don't know what you are looking at is not the fault of the tool....
amirm
Banned
Apr 2, 2010
15,813
37
Seattle, WA
Well it is if it won't let you change the vertical scale as in that graph. At least I have not found a way to get it to go lower so that I can see the spectrum.
Julf
613
Not sure you need to get lower than -90 dB if you can see a brickwall-steepness drop at 22.5 Khz...
Bruce B
Apr 25, 2010
7,006
512
1,740
Snohomish, WA
www.pugetsoundstudios.com
Yes you do... I've seen many hi-rez files where the engineer has applied a filter to a 24/96 or DSD file to filter out UHF noise. You need to go down at least to -144dB with a 24-bit file.
Look at my Post #2. This is a DSD file where I have just applied a filter. If you only went to -90dB, you would swear it's an upsampled file!
The graph on Post #3, you wouldn't see any content above 10k if you only went down to -90dB
fas42
Addicted To Best
Jan 8, 2011
3,973
3
NSW Australia
I was sure this was mentioned once before, Amir. Audacity is "smart" enough to know what information is, or may be present, and alters the vertical scale as necessary. A possible key thing is to make sure that the preferences setting for Spectrograms has sufficient dynamic range, I've got mine set to 144dB. I'm just looking at a waveform posted by Bruce some time ago, it's having no trouble telling me that the track has a level of about 148dB down at 86kHz ...
Frank
amirm
Banned
Apr 2, 2010
15,813
37
Seattle, WA
I post the side-by-side in the other thread . Here it is again:
In my book it is chopping off useful information.
Julf
613
Well, yes, if you have set it to 96 dB of scale. But as Frank points out, you can set it to 144 dB.
Julf
613
And that is something Audacity can so if you change the default setting.
Instead of just filtered in an extremely heavy-handed way. OK, not as bad as upsampled, but not much better.
Well, "no significant content beyond 10k" is also valuable information. Something that might be OK if the original master tape is from the 60's, but a reasonably modern master should have much more HF content.
Bruce B
Apr 25, 2010
7,006
512
1,740
Snohomish, WA
This was a Classical recording from the 90's at a very low amplitude.
Julf
613
OK, here is a 2011 recording, "Lay My Burden Down" from "Paper Airplane" by Alison Krauss & Union Station from HDTracks. Does not look pretty, but I don't think you can blame Audacity for the ugliness - the ugliness probably happened in the copying room.
amirm
Banned
Apr 2, 2010
15,813
37
Seattle, WA
I have changed it and it will make no difference on the sample file. If I feed a program 24 bit files as I am doing, I expect it to be that way anyway. Without it, we have tons of people complaining about stuff using that program for no reason.
Welcome to the forum by the way :).
Julf
613
That is why we need to help users with their settings. I find this link on computeraudiophile very useful.
Thanks! :)
Julf
