Equi=tech 10WQ Question
dminches
3,445
2,824
1,410
I own an Equi=tech 10WQ and I am wondering if having balanced power could cause any issues with non-audio equipment such as lights or record cleaners, etc. Do I have to be careful as to what is on a circuit being powered by the 10WQ?
Mike Lavigne
Apr 25, 2010
12,586
11,651
4,410
David,
as you know I've had the same unit since 2010. I have 'dirty' outlets next to the 'clean' outlets on the 10WQ grid. I always use the 'dirty' outlets for non signal path, non system gear such as lights. I have plugged three different RCM's into the 'clean' 10WQ power grid without issue.
up to now never had one issue that I know about.
dminches
3,445
2,824
1,410
David,
Thanks Mike. I don't see why other electrical devices would have an issue with balanced power but I don't know enough about it to be certain.
Mike Lavigne
Apr 25, 2010
12,586
11,651
4,410
I've been told if something has the internal ground not connected correctly, it can cause a short when using balanced power. but you would be talking modified or DIY gear, not commercial products. in other words, it's possible for a piece of gear to work right in a conventional outlet, but have a problem with balanced. but that should not happen unless a mistake (not enough care taken to do it right) was made in how it's wired.
I'm not knowledgeable enough to explain it more that that, although many here likely can maybe shed more light on the subject.
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
www.pugetsoundstudios.com
I've used the KLaudio cleaner and even a lava lamp into the circuit with no problems!!
dminches
3,445
2,824
1,410
This is all good to hear since I have a 2nd listening room and I want to power it with the Equi=tech.
Folsom
6,029
1,501
550
Eastern WA
Do like Mike, dirty and clean outlets.
What you never want to do is mix the two. For example amplifiers into dirty and preamp into clean.
dminches
3,445
2,824
1,410
I guess my question is do I need dirty outlets, and if so, why?
Mike Lavigne
Apr 25, 2010
12,586
11,651
4,410
noise. keep it out of the system power grid. dynamics. retain and optimize it. refinement. get all you can.
so you isolate any non system uses to the dirty outlets......if you can. adding ancillary gear to your protected system power grid will never help, it can only be neutral or bad. so in a perfect world you would have both 'dirty' and 'clean' in your room.
another benefit is the opportunity to A/B gear with either separate grid to know what is doing what. if you try a change it just gives you valuable data points.
when manufacturers bring gear to my room to test a few have claimed their gear was impervious to power grid conditioning. wrong. 100% of the time it has been easy to hear the benefit of the 10WQ.....so far.
just my 2 cents, YMMV. and only what I've heard in mine and a few other Equi=tech systems. there are those that don't agree.
Folsom
6,029
1,501
550
Eastern WA
As Mike says, you keep the power cleaner for the stereo by having dirty sockets. Any differential noise from lights is not attentuated by the Equi=tech when it is aldeady on the secondary side, for example.
dminches
3,445
2,824
1,410
Thanks guys. Makes sense.
Speedskater
941
15
368
Cleveland Ohio
a NEC balanced power rule:
647.7 (2)
on receptacle lable:
WARNING - TECHNICAL POWER
Do not connect to lighting equipment.
For electronic equipment only
note that Article 647 is a page and a half long.
