Ayon Apheris vs EMT JPA66 MkIII vs CH P1+X1
Tango
4,938
6,268
950
Bangkok
Wow Tang, superb insight. When you say CH is better on bass, is that only very low bass, or also Midbass?
Do you know when you are going to shift to do the test from another TT set up? Also if the difference in much lower output carts is larger?
The EMT and Ayon has excellent mid bass. Only low bass that P1 is clearly better.
Tango
4,938
6,268
950
Bangkok
Have you ever tried your EMT going directly into the amps ?
No. Too many cables switching hurts my back. Also my system requires two sets of outputs. The EMT has only one.
Kind regards,
Tang
Tbzc
89
100
938
Tang, hi.
A bit off topic: if I see correctly you have a Ayon Conquistador preamp. Would you be so kind and describe your experience with it, compared to your previous preamps. If my memory serves me well you had Spheris III which I also had and found it to be an excellent preamp. Thanks.
Tango
4,938
6,268
950
Bangkok
Tang, hi.
Hello Tbzc,
I told Gerhard that changing from Spheris III preamp to the Conquistador was the biggest improvement delta in upgrading any equipment of the Ayon brand. The Conquistador is like a Windex window cleaning liquid. I got super transparency and air between instruments moving from Spheris III to the Conquistador. I am not a very trained ear audiophile Tbzc. I don’t have bat ears hearing and detecting every small changes in sound and photographic hearing memory when changing equipment like many gurus. I can only state the more obvious differences. While there would probably be more micro differences, those were the difference I heard and remember upgrading to the Conquistador.
Here is an internal of the Conquistador.
Kind regards,
Ang
Tbzc
89
100
938
Thanks for a quick reply, Tang. But has Conquistador retained musicality, organic sound and good bass despite higher transparency? Because we see many designers today striving for ultimate transparency but losing the natural flow and organic density.
Tango
4,938
6,268
950
Bangkok
The conquistador is a "better" preamp not just "different" meaning no gaining something in the expense of others. It offer the kind of transparency that only enhances realism. And it still has a remote control!! :)
Kind regards,
Tang
