A1 or M1 for Rockport Avior
nickif
141
176
350
Hi guys,
I'm a CH D1+C1 user and looking for amps to drive my rockport Avior. The room is relatively small about 280 sqf, do you think L1+A1stereo is enough or L1+M1 is significantly better? In what way?
Thanks,
Michael
gian60
2,508
1,949
343
I have both,A1 mono and M1 mono
The A1 has a lot of power so in your case is enough.
I listen them in a shop with Rockport Cygnus and the sound is very good being the Rockport little dark and the CH neutral and very fast. and open and I think together are perfect.
My friend tried at home my A1 with his Wilson Alexandria and with some records we see the A1 display arrive at 500 watt
So A1 is enough but if you can buy M1 is better
M1 sound bigger than A1,all the instrument are bigger and the sound is more relaxed
Also L1 is fantastic for me
In future next step X1
Regards
jep123
293
106
908
Norway
Hi guys,
Thanks,
Michael
Kerem ( Absolare) have used his Integrated amplifier on shows, f ex in Munich with Rockport. You cannot go wrong with that amp, it is fantastic. I have the C1, D1 and X1 with this amp in the Signature edition.
Good Luck.
JP
jep123
293
106
908
Norway
Good Luck.
JP
This said, the A1 is superb too. I have heard it on several occations.
JP
gian60
2,508
1,949
343
Also you can buy A1 stereo and in future another A1 to use in mono
rsorren1
365
133
348
Dallas area
Hi guys,
Thanks,
Michael
Michael, My experiences with CH A1 and M1 suggest that you will be fine with a stereo A1 in your 280 sqf room with Rockport Avoir. My room is 350 sqf. I started with a D1/C1/A1 combination driving Wilson Alexia. No problems at all. The A1 provided plenty of power. When I switched to Zellaton Stage speakers, I traded up to the M1. As Gian60 points out, there are some differences in dynamics and scale with the M1. Both are wonderful amplifiers. My experiences suggest that you would be better served by buying an A1 and using the difference in costs between the A1 and M1 to add an L1 or X1 to your system. The C1 has an excellent pre-amp circuit in it but the L1 opens up the presentation considerably. Adding X1s to your system will lower noise floor, add dynamics and punch. Good luck.
nickif
141
176
350
Thanks a lot for your reply Gian, much appreciated! I know M1 is better but also twice the cost, therefore the headache.
nickif
141
176
350
Thanks very much Rsorren, your opinion is extremely valuable! I would imagine adding X1s some piont in the future as that's the fun of being CH user, there're plenty of upgrade options.
nickif
141
176
350
Good Luck.
JP
Hi JP, your setup looks awesome! I've heard lot good things about Absolare but it's difficult to get an audition here in HK.
nickif
141
176
350
I've thought about that option too, how do you compare A1 mono vs M1 stereo? As they cost almost the same.
gian60
2,508
1,949
343
I never tried A1 mono vs M1 stereo
I compare A1 stereo vs A1 mono and mono is better in weight,dynamic and fast,and the incredible thing is that you can biamp in passive way.
For example if your speaker can biamp or biwiring you can use A1 mono to use one channel for low and other channel for mid/high and you can select the gain of the amp for every channel,so if the sound is little dark you can increase the gain of mid/high
So i think A1 mono is better of M1 stereo
nickif
141
176
350
Thanks for sharing, but unfortunately my speaker doesn't allow bi-amp
jep123
293
106
908
Norway
Thanks. Send Kerem/Absolare an email and ask for a dealer in HK. Or a good customer of Kerem. But this is a CH thread and their products are very, very good. My experience with Rockport are with Absolare, go ahead with CH if that is your choice. You cannot go wrong either way. Good luck.
JP
nickif
141
176
350
I went to the showroom to audition CH A1 stereo powering Wilson benesh speakers 2 days ago, front end is CH D1+C1+L1, the sound is smooth, crystal clear on the top end but a bit lean and cold in tone color. Not to my liking very much I'd say. Hence I decided to try something else as well, tried soulution, nagra, so far I'm sold to Nagra. The classic amps in bridge mode as mono powering the same speakers, the sound was warm, transparent and somehow much more engaging than the A1, very seductive.
jfrech
2,156
751
1,160
Austin
Nagra is making some great sounds with their current line up !
SuperDave
252
78
158
Texas
nickif
141
176
350
gonna listen to these tomorrow, looking very much forward to!
Elberoth
2,010
258
1,170
Poland
