High Z or Low Z impedance RCA or XLR for MSB Analog DAC
alfa100
266
49
333
South Africa
I have high Z, XLR Transparent audio XLR interconnect from MSB Analog DAC to Pass Labs amplifier.
The Analog DAC is not a true Balanced DAC but still has XLR output .MSB states that RCA interconnect is better for this DAC
Pass Labs amp is true balanced.
I have tried the RCA version of Transparent ref with mm2 tech calibrated LOW Z . Comparing to XLR version but HIGH Z (mine) I find the following:
midrange , midbass and bass has more weight , but low low low bass weaker with RCA.
air between instruments not as good with RCA.
Comments are welcome
the RCA is calibrated for LOW Z and XLR for high Z.
MSB output impedance is 100 ohms on balanced and 53 on single ended .
If I recalibrate my XLR to low z will it be better?
Should I swop my high Z XLR for low Z RCA? I could bit I do not want to lose out on the low bass .
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
MSB impedance value measured is about 120 for XLR but 100 ACCORDING TO msb ......and 53 FOR RCA .
The cut-off for lo-Z is 100 Ohm, so at 53 Ohm you should use lo-Z calibration.
alfa100
266
49
333
South Africa
Hi edorr
the RCA cable I am trying is set low Z which is correct for Analog DAC single ended ouput impedance of 53 Ohm .
My Balanced cable is calibrated high Z. MSB states their Analog DAC output impedance is 100ohm in balanced mode. 100ohm is cut off point. Transparent audio says that they have measured the Analog DAC has 120 ohm impedance on balanced output. hence should I recalibrate my XLR to low Z
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
Hi edorr
At 120 sounds like the balanced should be a Hi-Z but easiest is asking Transparent. They are very responsive.
alfa100
266
49
333
South Africa
edorr
sorry my mistake
the MSB is 100 ohms on balanced line as measured by Transparent Audio . question remains . as 100 is cut off is there any benefit in recalibrating lo Z on xlr cable?
apologies for error
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
edorr
sorry my mistake
apologies for error
At 100 Ohm, its a crapshoot. I would not sweat is and just use whatever you got your hands on and enjoy the music.
alfa100
266
49
333
South Africa
Thank you edorr
Agreed !!! and i wish it was that simple.
I often wonder why we bother with improvements or finding the best.
"addicted to the best"
jfrech
2,156
751
1,160
Austin
What in the heck is a Low Z analog interconnect cable?
And why would it matter?
Some cables, like Transparent, are tuned to match impedances between components. Hi z or Low z is the two versions in this particular cable. Other Transparent cables are precisely matched to each component. If you change components...you have to send the cables back to be retuned...
Here is more info from this manufacturer...a few other companies do this as well...
http://www.transparentcable.com/design/audio_cable_networks.php?catID=1&modCAT=1
http://www.transparentcable.com/design/audio_cable_networks2.php?catID=1&modCAT=1
Speedskater
941
15
368
Cleveland Ohio
alfa100
266
49
333
South Africa
i now have Transparent Audio Ref MM2 XLR low Z...... sounds great;
Better than high Z XLR and better than low Z RCA of the same Ref MM2.
As expected I had to make changes to speaker position and wait for cable to burn in and settle down. the process drove me nuts. I hope I never have to go through this again.
