As a result it’s better and correct way to adjust azimuth according to maximum channel separation and minimum phase error up to 1-2 degrees. If You need to tilt more than that than change the cartridge or use it as it is. Reducing phase error is more important cause human ear is very sensitive to phase error. IMHO using AP test disc is very good for setting azimuth.
Just to be sure, What phase error are you referring to? The the phase difference from the Main channel to the channel with crosstalk? Or…As a result it’s better and correct way to adjust azimuth according to maximum channel separation and minimum phase error up to 1-2 degrees.
Phase error can result from misaligned cartridge coils. Ideally, the coils for both left and right channels should be aligned at a 45-degree angle to the vinyl surface (in the horizontal plane). However, when using the Korf method to adjust azimuth by aligning the stylus perpendicular to the groove (in the horizontal plane), phase errors may occur. This is because the axis of the coils, which ensures optimal channel separation and minimal phase error, doesn’t always align with the axis of the stylus.Just to be sure, What phase error are you referring to? The the phase difference from the Main channel to the channel with crosstalk? Or…
Thanks.
I just found a figure that illustrates why/when crosstalk shifts from being In-phase with main signal, to out-of phase.
The figure shows a situation where the Azimuth is at an angle that gives In-phase crosstalk. Imagine the angles tilted more anti-clock wise, ( Azimuth adjustment) then the arrow for the crosstalk will change direction , and therefore the crosstalk channel will become out-of phase.
Optimal Azimuth occurs when cross talk switches from in phase to out of phase or phase curves cross? . At that point the crosstalk should be at minimum and close to equal.
But the misalignment may be both on coil/generator and stylus tip. So phase change and lowest crosstalk may not coincide.
See top figure, I could not place it below here where I wanted it..
The figure is made with AT95E on a test record that have varying groove cut , 40-50 degree for Azimuth check. Using a 400 high pass filter to get a clean azimuth signal 1khz
This is where I jump in with my usual rantwith a test disc you believe is cut with correct azimuth
I have the same experience;This is where I jump in with my usual rant, by observing that in my own experience owning probably at least a dozen test records, with multiple copies of some, that I can’t find two of then that yield reasonably close results for channel separation. In many cades the differences are significant. It frustrates the you know what out of me.
This is interesting!My Figures:
Thanks Calle_jrThis is interesting!
But just to be clear;
What are the different figures representing?
Are the two first rows crosstalk dB levels?
What does VTA=2.9809 mean?
That I get.Please check the Analog Magik website to fully understand figures.
Thanks Calle...the point of the figures is that Azimuth is set depending on which LP you choose for your Azimuth adjustment....thus setting for one LP depending upon its mastering / pressing etc. accuracy you may in fact be miles out...so which record do we choose and trust....the figures are wildly different ......That I get.
And for the azimuth I see what you’re doing. A few notes;
- The levels on the different test LPs are not the same, which means the crosstalk waveform will be more or less good looking, signal disturbances will influence, rms calculation will differ etc. I would assume this may impact some +/-1dB or so, so absolute values must be cautiously interpreted.
- Using two decimal points on dB values only makes it more difficult to read, see previous note.
- The main objective is to minimize the crosstalk difference between L and R channel. The spread is really big, it even changes sign.
For the IMD percentages, the tracks on the test LPs are totally different. Some of them are not even IMD tracks, and the track on AM I is not the same as on AM II.
They can’t be compared, and especially not with four decimal points. Not even without decimals.
THD would be more comparable, but again, the levels are not the same between the test LPs.
I don’t see the point in adjusting VTA based on L and R channel readings.
