I am not German, i do not fall for that gimmick !One really good motor is good enough for me.
I thought Americans did the selling, Germans did the engineering, east Asians did the buying, and Swiss did the pricing.
Not the ones I know. A londoner has had it for years and excellent and serviced well. Vienna when he bought his did many measurements and he bought more on measurements than listening, and BB topped with SME in measurements. Dcc had it, you can ask him, he replaced his with CS Port but liked the BB all through. And Marc Gomez recommended it to Tang over higher priced tables, am sure he is technical enough to measure it. Though I personally don't know if any specific test has been run on it to confirm that.
Thank you, might have been an isolated opinion.Not the ones I know. A londoner has had it for years and excellent and serviced well. Vienna when he bought his did many measurements and he bought more on measurements than listening, and BB topped with SME in measurements. Dcc had it, you can ask him, he replaced his with CS Port but liked the BB all through. And Marc Gomez recommended it to Tang over higher priced tables, am sure he is technical enough to measure it. Though I personally don't know if any specific test has been run on it to confirm that.
I had a BB for almost 10 years and never faced speed control issues (I had a Roadrunner for measuring the speed).Not the ones I know. A londoner has had it for years and excellent and serviced well. Vienna when he bought his did many measurements and he bought more on measurements than listening, and BB topped with SME in measurements. Dcc had it, you can ask him, he replaced his with CS Port but liked the BB all through. And Marc Gomez recommended it to Tang over higher priced tables, am sure he is technical enough to measure it. Though I personally don't know if any specific test has been run on it to confirm that.
BTW, is Brinkmann Sinus motor and Ront III available to be purchased separately from the TT itself?
Some people do but many things on measurements, including flat measuring speakers. With TTs they check wow and flutter. Sure they’ll listen as well, but not everybody backs their listening audition as some are quite humble on that front and don’t think that putting any LP on is actually judging the soundDo people really buy turntables based on measurements instead of listening? SME turntables measure extremely well, but other turntables sound better.
Me not like the design… It may sound great but wouldn’t buy it, due to the looks - I don’t like it. To me it looks more like something you can process hay - and get flour out on the other side… sorry to say !
As Tom Waits sings: "Step right up " !I thought Americans did the selling, Germans did the engineering, east Asians did the buying, and Swiss did the pricing.
Yes, you can buy them separately, BB comes with sinus motor.Thank you, might have been an isolated opinion.
I thought that the Funk Firm solution, one motor and two additional passive pulleys solved the issue of motor sync and still distributed the force around the platter. Also, he thinks that arranging them assymmetrically eliminates resonances that can come from symmetrical placement of the motors/pulleys.you should go to Göppingen, Germany and see the production, then you will change your mind, I think. Also a beautiful landscape, the Stauferland.
P.S
clever solution to position the motors so that the bearing load is equal at any angleView attachment 130450
I think new BBs come with SInus motor already and RONt III is an option to the normal motor controller and can be bought later if budget doesn't allow for it up front.Thank you, might have been an isolated opinion.
I think asychronous loading leads to faster wear and higher friction. A defined belt tension is important, then it will work with fewer motors.I thought that the Funk Firm solution, one motor and two additional passive pulleys solved the issue of motor sync and still distributed the force around the platter. Also, he thinks that arranging them assymmetrically eliminates resonances that can come from symmetrical placement of the motors/pulleys.
Lots of noise potential and assume all motors run at exactly the same speed...big assumptions I think. I remember my 3 motor Voyd. it was dynamic as hell but noisy, which made things sound a bit "dirty".I think asychronous loading leads to faster wear and higher friction. A defined belt tension is important, then it will work with fewer motors.
The big advantage of the concept, in my opinion, is that the 6 AC motors do not require speed control. They are not dependent on the applied voltage, but only on the frequency of the voltage. Speeds of 33/45/78 are achieved using digital frequency converters. Since synchronous motors do not develop a large torque from a standstill, 6 motors are probably needed to quickly bring the platter mass up to speed.
