Reactions: morricab
I want to thank publicly Norman Cones of Stereo Squares for a perfectly fabricated and fitting acrylic cover for the Balance turntable.
I highly recommend Norman's work!
Contact:
Norman Cones
Stereo Squares
(616) 291-9433
stereosquares@gmail.com
Contact:
Norman Cones
Stereo Squares
(616) 291-9433
i like it. very classy.
is it heavy? i notice no handles. will fingerprints annoy you?
Reactions: Johan K
Contact:
Norman Cones
Stereo Squares
(616) 291-9433
I went to a demo by Dr Matthias Lück of the Brinkmann turntable with the valve power supply and Edison II phono and was hugely impressed. He brought along one of his copper master discs.
I do like perspex - made my own audio rack from perspex.
Reactions: Johan K and XV-1
Thank you!
No, not heavy.
What makes you think I have dirty paws?:)
I generally make very liberal use of alcohol wipes before I touch acrylic covers or records or tapes -- so I don't get fingerprints on anything.
Good idea on the alcohol wipes! I haven't come across this before, so thank you.
Reactions: Ron Resnick
nothing. fingerprints don't need dirt. just normal hand oils. and constant wiping your hands with alcohol can really overly dry your hands too. i need proper control (dexterity) to flip my records confidently with the platter turning.
suppose it depends on the frequency of use.
be careful as many types of alcohol will cause acrylic to get cloudy and develop microfractures. as you are thorough, talk to Norman about it so you start out knowing what method is best. maybe those first aid kit wipes are perfect?
Reactions: Johan K and bonzo75
Did you consider an Atmasphere MA-1 to the panels? It has an excellent balanced input, it would be ideal to your long cables.
Yes; I love the crystalline transparency of OTL, but it always reads lean to me -- the exact opposite of what I need for the Pendragons.
You mean from wiping my fingers with the alcohol pad and then lifting up the cover? If so, not enough alcohol gets transferred to the cover to do anything.
yesterday i listened for 4+ hours and flipped sides 20 times. are you saying the cover stays off during sessions? you won't play with the cover on?
even if you move it twice a day for 6 months, that is lots of alcohol in the same place every day. i guess you could hold your hands in the air for 30 seconds every time prior to touching the cover. how long after the wipes are done can you smell alcohol on your fingers?
Actually, I love both.
Correct. I will not play records with the cover on.
Worrying about this is waaaaay too OCD for me.
I am afraid I don't know. Finger sniffing doesn't turn me on.
Reactions: Johan K and Lagonda
The one I heard that didn’t have that leanish character was the Tenor OTL. Apparently, the Joule Electra ones were also somewhat rich sounding but I never heard them.
Reactions: Mike Lavigne
Cover over turntable? That makes records sound like plastic.
