I’ve just completed the FPGA firmware upgrade on my Terminator Plus DAC. The provided instructions by Denafrips are detailed and if followed correctly, the upgrade should occur without any problem. The only caveat I encountered was the last step of the upgrade, where Denafrips indicates the firmware can take up to five minutes to be downloaded. On my first try, I‘ve waited about ten minutes before I stopped the process. It looked like the download process had an issue (no progress). Tried a second time with same issue. Contacted Vinshine Audio support team (Vincent) and he indicated that everything I’ve done was correct. Vincent indicated that I should be patient and wait for the process to complete itself. So I used my IPhone timer set at 15 minutes and checked the firmware download at each 15 minute intervals. At around 24 minutes of download, the process was completed.
In my audio setup, I am also using a Denafrips Hermes DDC. Once the DAC firmware upgrade is completed, the DAC returns to its original manufacturer configuration. So you need to take note of your DAC configuration prior to the upgrade and reconfigure the DAC settings, once the firmware upgrade is completed. You will also need to perform the clock synchronization procedure for the DAC and DDC to operate correctly (see Vinshine Audio YouTube video on this subject).
Was this worth all of these efforts? Absolutely!
The upgraded T+ provides a blacker musical background. It seems like the noise level was brought down and I’ve been cranking up the volume level by 3-4 db. There is an increase in musical instrument delineation, bloom and ‘thereness’. I’ve listened to to ‘Superstar’ on Diana Krall’s ‘Wallflower’ album. It was like her singing to me in a private concert. Her voice was luscious, natural and very present, scary present…
The firmware upgrade will not change the audio qualities of the T+ DAC. I did not perceive any tonal changes in the sound of the DAC. It’s like having a series of audio bonuses being added to the DAC. I’ve listened to multiple albums for a few hours in a row, without any listening fatigue. Denafrips offers the T+ owners the option to return to the original FPGA firmware, in a situation where the user would prefer the original sound of the T+. In my case, I will never return to the original firmware, since the upgraded firmware is such a winner! This upgrade is a no-brainer.
