I heard them with UR too. Don’t remember the model it was around 25 watts. Didn’t like it with iti had spend couple of hours for several times with O/96 and O/93 they were connected to Unison Research simfonia, Unison Research Unico 150, and we also tried them with Moon 860 amp and 740 pre amp.
while I very much love the sound of those devor speakers, especially with the sinfonia amp, I choose going on at another pathway which to my pref suite my taste.
for some of the reasons I didn’t go with devor speakers, I have chosen not to go with horn loudspeakers, all ought my reference (belonging to close friend) audio system is based on a horn speakers.
Vitus, Kondo, levinson, Alieno, Dagostino momentum’s, MBL, FM acoustics, symphonic line 300w.
i know and like Luxman as a low price good value SS amp but it will not be suitable for Devore imo. And based on the Jadis experience, the VAC will sound like another higher powered push pull amp.
it is the NAF 2a3 and airtight 300b category it needs. Speakers like Devore allow you to use a simpler chain which makes the whole system sing, if you apply same principles of using a higher powered SS or push pull amp there is no point in getting it
the whole point of Devore is compromise until one can afford a horn. AN has varied cost, so why would someone get the higher priced AN instead of getting the horn? I would never have recommended Devore if it was 50k. The fact that it sounds better than many 50 or 100k speakers is different.
Unfortunately the Magico will require those bigger amplifiers leading to a much different sonic signature.
Does this make the Devore Better? when worse on SS better on flea powered toobs, this is the bent rod in Audio, surly if one has flea power the Devore is the better choice ..!
Not necessarily the better Speaker ..!
They do sound musical, but to me they are copies of the principle Saba Greencones with vibrating housings. there are a lot of fans of these speakers outthere.
For those who are interested in such loudspeakers, I recommend the book "Höchst empfindlich" where it describes what the magic lies that captivates many people.
Not when you couple with a weak bass SET, the balance becomes perfect and tone rich ..!
With an amplifier with equal drive across the frequency spectrum its different.
aside ,
don't discount what the SET brings when it latches on to a likable impedance curve ..!
well recognized...respectIs that a C22 ..?
Has anyone listened to new Sasha V?
In your opinion what's the right price?
