in the photos for the beautiful system in Viet Nam, there is one that shows a full screen xdms image of what looks like an album cover. i have yet to see that screen view in my system, although i do get the mini-player at the bottom.
(Searching for an Audiophile Grade Ethernet Switch) By Robert Witrak, President & Chief Engineer, HDTT We have been using Merging Technologies ADCs and DACs for years now, in conjunction with the Ravenna network, which Merging implements to distribute the signals via ethernet (RJ45). It is a...
Forty years ago some quaint little discs were released that would, we were told, revolutionise the way we listened to music, offering undreamt of naturalness and astonishing fidelity to the original performance or existing analogue master-tapes. However from the moment they appeared there was...
Thanks - very interesting comments. It is nice that they use Merging products - some of my best digital recordings were recorded using Merging recording solutions.
Yes we actually most likely will. In this case we‘d be looking for a degree market adaptation and this has been a very expansive project meaning it would probably end up retailing at the same 10-20K if only purchased by say just 20% of Extreme owners currently owning a DAC in that price range…
I am not sure I realize what is the full value offered to an Extreme user by the PCIe card.
It is clear that an user without a top flight DAC (as myself) could benefit from the onboard DAC, but I assume that most Extreme users have already a DAC above 20k, or (as myself) have one in the purchase pipeline, aiming to the best possible SQ.
As I understand it, the upcoming PCIe card will not be equipped with the TACDD proprietary physical interface. Is it correct?
However, given that the PCIe card will have "regular" digital outputs, I assume that they will provide better SQ than USB to an existing DAC.
If that is correct as well, the roadmap for an Extreme user aiming to top SQ would be in the short term to get the TACDx card and using it as a DDC (digital-to-digital) converter only (limited to 24/192), connected to a top flight DAC via e.g. BNC, and wait for a future development where Taiko provides a new PCIe card equipped with the proprietary interface, and the receiving DAC has the corresponding interface available.
Finally, I understand that the DAC receiver module could be installed as a retrofit of a current production DAC and does not necessarily require a DAC developed from scratch with it.
The value is:
-a start with addressing one of the largest SQ limiting issues in high res digital playback
-being able to offer a much requested feature (one box solution)
-significantly upgrade our SPDIF output option
-a potential direct upgrade for about 20% of our customers
-expanding to a medium timeframe upgrade for about 60% of our customers (2023)
-over a longer timeframe possibly providing an upgrade to 90% of our customers (into 2024)
We‘ll have several options when the time comes, our focus though has shifted to as much in house manufacturing, finishing included, as possible, this may affect the options we‘ll offer.
The value is:
Am I interpreting this correctly...
1) The 20% for a direct upgrade are the customers that have a DAC worse than the PCIe onboard DAC plus maybe some that have no or non XMOS USB DACS and/or want a one box solution (server plus DAC)?
2) the additional 40% are all that could replace the XMOS or Amanero receiver in their DAC with an upcoming TACDD receiver replacement board?
3) the rest is the ones that can count on direct TACDD implementation by DAC manufacturers you are working on a collaboration like MSB or Lampizator?
4) as the first next gen card is not meant to replace the USB card, it will not provide superior sonic performance via SPDIF vs the current USB option - leaving the sample rate limitation to 24/192 a side of course? So no intermediate upgrade track for current XMOS DAC owners?
1) Yes
2) Would be MSB Pro ISL, and other I2S interfaces
3) Yes
4) Yes and for first gen XMOS dacs which are typically limited to 24/192, Berkeley DACs etc
Not sure, the thing is, the more time we spend with it, the more improvements we find, parameters effecting sound quality, some expected, some unexpected, even just the driver code has an incredibly large effect on the resulting sound, what we are used to listening too is severely compromised with regards to transients, dynamics and timing but also texture, spatial information, decay..
Bottom line, we‘re just getting started here, it‘s brand new technology.
I would like to confirm please,
if you are using the TACDA card with the analog/RCA output, you can play any format PCM/DSD files, and any resolution i.e. PGGB files that can be processed by your CPU?
do you have a ballpark for the cost? $3k and under, $5k and under?
For the new Switch, can Taiko tell us the specs of the DC input barrel, so we can order a suitable linear power supply?
- polarity (e.g., inside negative)
- inner and outer diameter
- voltage and current requirements
Polarity is not standardized, so anyone ordering a LPS should be careful to get this right. Not sure what happens if you reverse it, perhaps just blowing a fuse?
