Witch one is Marc ?![]()
I am more interested in who is Chief?
And who already got their lobotomy
I had a loboxomy when I went over to panels and OB… so now I’m just mostly baffledI am more interested in who is Chief?
And who already got their lobotomy![]()
Modern prog is an oxymoron… then I also never thought the mullet as mainstream hair do would return in my lifetime eitherThey are called a prog group. I didn't think they were when I heard them.
Yes K70
The Chief is obviously Indian !I am more interested in who is Chief?
Seems you are openly baffled to the WBF!I had a loboxomy when I went over to panels and OB… so now I’m just mostly baffled![]()
If you’re not actually offering anything new then it’s not really progressive…Modern prog is an oxymoron… then I also never thought the mullet as mainstream hair do would return in my lifetime either![]()
and not sure that it qualifies as renaissance eitherIf you’re not actually offering anything new then it’s not really progressive…
At least that song sounded like limited guys making limited music. Would need to hear a few more tracks…and not sure that it qualifies as renaissance either![]()
K70 is a hybrid. Every time I heard those systems they sounded as you described.Separately, he had a metal armboard installed on his Vyger Indian for Da Vinci Grandezza which had a DST master. I thought it sounded so bad in comparison I didn't do a video. It is possible that was because it was all SS chain (Dagostino preamp and Koda K70) while the LT with MSL went through the Allnic 5000 phono. The DST does have a lot of detail, slam, and big stage. It is spiky, especially on large stuff, and very digital. Would like to listen on a valve system, and with the tube encoder for DST coming in. Crazy price so pointless imo
A few thousand $ pivot is good enough. Get you enough wet.I didn't find it dry.
Tang has the same recording. He can post it to see if wet through all valves.
This is one where the linear tracking table Holbo is less than 5k used, lowest model of Ikeda cart, and TAD 2402 look alike LALS from Taiwan playing on 300b.
I will also post the chaconne on harmonia mundi on this system. That way you get to compare two recordings in same system and the same record across two systems, so your query should be answered.
Across system one is high priced and one is low priced but there is definitely a lot of valve to this one to address the dry doubt
So you don't hear I am missing any highs. This is playing Neumann DST with frequency only goes up to 17k. Maybe now that I said 17K, some people start to hear no high all the sudden...haha. I was worrying about the Klangflim only goes up to 17K too. But after living with Neumann I am not skeptical of the Eurodyn not delivering me enough high that I can hear.I have never heard the Neumann do violin on yours so I don't know what it sounds like but this sounds more like VDH. If you record it with Neumann, we will be able to get a better understanding of the pivot.
How is the sound of Sumile?Looks much more beautiful in person. The CS Port with Sumile on the LT, and the Durand Tosca with Lyra Atlas Lambda. Rest of the system was CS Port phono, Pilium preamp and monos, and Sonus Faber Venice, at Amadeus Audio (Ertugrul). He is the Dutch distro for CS, Durand, Pilium, Stealth.
Had nothing to compare it with, as the Audio Tekne TT is not set up at the moment, but the linearity through the midbass, the bass and extension and dynamics of the CS were amazing. Some records did well on the LT and some with the pivot. Ertugrul says he listens regularly and for him it is approx 50% each. There definitely was a case to have both. Also, the Atlas Lambda is the first Lyra I have found musical (I haven't heard the Olympos), and would love to hear the Lambda on the LT.
