Thanks for the info... it's unlikely that I would have time to actually build something myself. I'll have to write another check for this one. I do have a slab of granite which may come in handy.
i have 8 sets of 4 A10-U8's and use the Adona racks which are solid and grounded (and reasonably priced). my tt is Wave Kinetics and comes with it's own isolation system which is meant to sit on a grounded rack. by 'gounded rack' i mean a rack with a direct spiked connection to a solid floor and some degree of mass to firmly 'ground' the rack.
my system sounds the best it's ever sounded...
Yes, but it would show the isolation racks in a positive light if audible levels were measured. It would provide evidence of long held, unsupported claims that I'm sure would be very useful.
ON EDIT: Actually, I would expect the hardware manufacturers to measure and show the results as well, if these effects are audible. A manufacturer who has built a chassis and foot system that solves the problem and out performs other amps as a result, could present it as a competitive advantage. And in fact, such manufacturers often do make such an argument. But I don't ever recall them showing measurements of audible effect on the amp's performance. Not saying it isn't so, just wondering why it isn't shown.
Tim
Wave Kinetics...run by Jonathan Tinn...does provide measurements of speakers before using their footers...and after. Not being a techie, i am always skeptical of measurements...like statistics...since i do not know the science myself. However, they do provide the measurements and did so for the interviewer on his own system at home (who printed them i believe).
I would be interested to read such a review. Would like to see what it changes about the speaker response and our perception of such ... To me it is not so mcuh that certain phenomenon occurs... I am sure if you shake some capacitor, there may be a change in electrical behavior that could be measurable. My point is that is it audible? Can we reliably perceive such minute changes ? Many swear they can ... When knowledge is removed the perception ends almost always to disappear ... This will not be settled in this debate or others.
I do know and can verify it with many audiophile that the perception of such changes with many isolation devices is not as dramatic as what one gets treating his or he rooms or changing speakers. For the OP that remains my advice. What you would have spent in Isolation devices, Spend it right now on Room Acoustics .. If you are very new to this or even for those with more experience on the matter, the best remains to talk to a person who deals in Room Acoustics Treatment some of hem in this very forum.. That will provide you with the best sound for your dollars or whatever your local currency is , then and only then you play with those expensive isolation devices and strain to to hear differences .. Depending on your persuasion you may hear some ... Even if there are none ...![]()
You will have to speak with the manufacturer. here is the review by positive feedback. http://www.positive-feedback.com/Issue46/brutus_awards2.htm unfortunately...the measurements they used were not printed.
EMphasis is mine .. Curious ...![]()
Mike
I don't think they were right to quote you "amazingly so" .. What you are appreciating right now on our system is based on science however way you look at it ... Measurements brought them to you .. every single part of your system or mine or anybody's ... Thus my insistence on a way to measure things.. To be able to repeat things .. No to ge to something by sheer luck .. Imagine the odds to get something right without measurements or the trial and error from those who don't have easy access to equipment ... or whose budget has limits ... That,s to me what measurements are about.
Running with the two prior posts...
Is there an expectation bias for measurements? That is, if something measures better, do some people expect the equipment to sound better? This of course assumes that what we are measuring will have a meaningful impact on what we perceive as sound quality. For example, is a 500 watt SS 'better' than a 50 watt tube amp if the have the the same THD, IMD, etc?
Myles
I would be pleased to discover a drug that cures such a serous disease but let me turn the tables on you .. What are the odds of myself an engineer coming up with this drug if I weren't researching it. By stumbling on it? .. How would I test its efficacy if not by measuring some things even if those were the ingredients in the potion I came up with ?
So the Audio designer in his lab just concoct the greatest isolation device by pure accident? Chance or the superb amp by listening at it ? Just by listening, never measuring anything so that he can later replicate his wonder-product? I can understand we are not at the point where we can correlate all that we hear with measurments but we can correlate some ... Isolating something from vibration is a technology with known parameters and they were measured .. If we understand how they are measured and how what is measured correlate to what we hear we make an advance ... Now if you believe that our senses are not fallible and subject wide variations in accuracy ... It becomes a belief that the present state of knowledge belies .. but you can choose to ignore that too ...
To remain on topic and to repeat myself here .. Considering the OP question about Vibration Control aka Racks for a system he is building apparently from scratch .. Vibration control lays , literally at the bpottom of system priority and budget .. wouldn't you think? I am not calling them "racket" but I doubt anyone can think of Room Acoustics as "racket"...
