Resolution is something that happens at the court.in music the closer you can get to the real thing.
I find my Magnapan 30.7s to be very high resolution as you can easily hear the difference in recordings. Bad recording sounds terrible as the high resolution shows it of and high quality lps and cds sound amazing As it was live in the room.
Yes most speakers let you hear the difference between recordings but is it in a high resolution way.not always I believe.Don't most speakers allow you to hear the differences between recordings? What do you think is the relationship between this observation and resolution?
even my cheap bedroom system shows of good and bad recordings but not in a high resolution way.nothin on it sounds like music is live in the room.high resolution makes a good recording sound live.A to H is talking about the difference between good and bad recordings (bad might sound compressed, for example). This is different from another difference in recordings, where the ambience and stage and venue of the concert differs from record to record (assuming all good quality records). The latter is not shown on most speakers/systems as systems force a certain stage over the recordings. I call this transparency to recordings, not resolution.
tima,If you sit in a concert hall during an orchestral performance, what do you hear?
If you sit in an audio room listening to an orchestral performance, what do you hear?
Is there a point where greater resolution causes an audio system to sound less natural?
Of course there is.
A transparent, highly resolving system should have the ability to make every thread in this densely-woven sonic tapestry clearly and accurately audible as a separate entity.
Both hi-fi systems and recordings have their own inherent resolution so you can listen to a high resolution recording on a low resolution hi-fi, a low resolution recording on a low resolution hi-fi, a high resolution recording on a high resolution hi-fi and so on. A high resolution hi-fi system will allow you to hear greater (clearer) differences between low and high resolution recordings. Changes in the linearity of frequency response is not the same as changes in resolution. The former will colour all recordings, the latter will reveal greater differences between recordings.Don't most speakers allow you to hear the differences between recordings? What do you think is the relationship between this observation and resolution?
As a photographer, my experience over the years, is that modern digital capture and printing surpasses film/dark room in every one of the parameters you cited above— including naturalness. It all depends on who’s doing the work.Ron, I'm not sure video is a relevant comparison. However where it may be is on film type. I remain convinced by film over digital, despite "artifacts" like film grain.
Techies will say digital has greater resolution than film, and it may well do in pure detail terms, but I rate warmth, texture, saturation and black density/contrast levels better on film than modern digital.
Fully agree and when both come together the magic starts and you can call it " high end audio "Both hi-fi systems and recordings have their own inherent resolution so you can listen to a high resolution recording on a low resolution hi-fi, a low resolution recording on a low resolution hi-fi, a high resolution recording on a high resolution hi-fi and so on. A high resolution hi-fi system will allow you to hear greater (clearer) differences between low and high resolution recordings. Changes in the linearity of frequency response is not the same as changes in resolution. The former will colour all recordings, the latter will reveal greater differences between recordings.
A while back I recorded a few tracks of me playing my Gibson SJ200 Custom Cutaway.
Playing it back through my system at high volume was just a staggering experience. I was totally blown away by how much more I could hear it terms of detail than when actually playing the instrument.
Like the equivalent of an audio magnifying glass. The whole instrument's presence gets magnified by two much larger emitters of sound i.e. the panels of my planar magnetic speakers, capable of far higher playback levels.
The point is playback systems are capable of providng higher resolution than the original instruments.
Just to mention, there are no square waves in music….but your point is still valid that the majority of speakers can’t provide the dynamic response required to track the initial percussive attack of many instrumentsI think subjective impressions of resolution may well come from the speed of loudspeaker drivers.
AER BD4 is a fast driver, I believe, and you can hear it certainly is very high resolution.
Not many drivers can track a square wave input well. Planar magnetic / true ribbons loudspeakers at least make a decent go of it.
You can certainly hear this speed I think in Alsyvox and Apogee speakers. Less so in Maggies but there's less force per unit area in those as they use fewer magnets.
AG horns sound pretty quick to me and I reckon they must be 'fast' too.
Yeah you got the point totally - that's the point of the square wave test. Obviously it can be performed at various different frequencies but to be great the speaker must perform well over the entire frequency range.Just to mention, there are no square waves in music….but your point is still valid that the majority of speakers can’t provide the dynamic response required to track the initial percussive attack of many instruments
I agree, looking at a frequency graph, relative linearity does not indicate that one component has greater resolution than another. However, emphasis in a frequency range can give some the impression of greater resolution compared to a component without that emphasis.
