If you still spin CDs, this may be the best option.
thomask
1,662
1,611
295
65
Washington State, US
On 25th, May, I went to Yongsan Electronic Land, Seoul, Korea.
With this combination, it sounds effortless, very detailed with clear focus, deep and wide soundstage.
It is one of the best high end sound that I had ever heard.
The front end was Metronome Kalista Reference 30 year anniversary model.
Ypsilon Aellus monoblocks and PST100 pre amplfiers was used to drive 150K$ Avalon Saga speakers.
http://www.avalonacoustics.com/models_saga.html
The specification of Saga is
Driver Complement:
1" Concave Carbon/Glass Neodymium Tweeter
7" Concave radial magnetic Ceramic Midrange
(2) 13" Nomex Kevlar Generation II Composite Woofers
All drivers utilize proprietary neodymium magnetic technologies.
Sensitivity:
92 dB
Impedance:
4 ohms nominal (3.8 ohms minimum)
Frequency Response:
20Hz to 45kHz
Recommended Amplifier Power:
25 to 500 watts
Wiring Methods:
Dual binding post
Dimensions:
68" high (178 cm)
14.5" wide (37 cm)
17" deep (43 cm)
Weight:
260 pounds each (118 kg each)
Kalista Dreamplay transport and Dac with two separate power supplies look grand.
https://www.hifiplus.com/articles/kalista-dreamplay-cd-transport-and-dac/
This Kalista Dreamplay transport and Dac is not cheap with price tag of 100K$.
But it seems to match the sound of MSB Select II with transport.
I am getting strong temptation to snatch this beauty.
I have to check my bank balance after going back to my home in US.;)
This is my first encounter with Ypsilon amplifiers and I am also deeply impressed with the quality of its sound and relatively affordable price.
PST100 pre amplifier has both active and passive mode.
Passive give more transparent sound while sacrificing little bit of dynamics.
Yongsan Electronic Land used to house more than 200 high end audio shops about 15 years ago, while it had dwindled to around 100 shops now.
But it is still one of the best place to audition high end audio and vintage audio.
As I go through the top digital systems in Korea, it is getting more difficult to choose one to replace my 10 years old EMMLab Dac2( new price was 9k$).
Thomas, I heard a Metronome cd transport/dac combo 3-4 years ago at the ML Neolith launch in London. I was a little underwhelmed by the sound, it seemed very "digital", w little analog flow or texture. Hopefully this combo does better.
Reactions: Folsom and thomask
As I say often you were unlucky - I still keep my Metronome Calypso Reference / C2A DAC. Although it has less detail and grip than the Vivaldi, less defined bass and surely is more colored, it has great texture and flow.
My distributor does not have the new Metrome Kalista DAC in stock, otherwise I would surely want to listen to it in my system.
Thanks for your input.
I am not so sure whether they had improved since then or some system matching.
I had listened to new 30 years anniversary limited version.
This one sounds as good as MSB Select II.
This new version has deep bass and lot of details.
Now they may have hit the Jackpot.
The new version has two type of selectable DAC chips and SS or tube output - it is like having a turntable with four arms and cartridges. Which option did you listen?
I had tried four different combinations.
I usually prefer tube out for more analog sound but while SS out has more transparent sound.
What tube is it using? With Lampi we found some tubes being less transparent while some are extremely transparent. 242 and 101d for example are extremely transparent. The lower down non DHT models with tubes like ECC82 types are not as transparent.
Reactions: thomask
Unfortunately, I have no information on it.
Tube is inside it so that tube rolling is not easy.
The default tube for Metronome Technolgie JAN-Philips 6922 green label tube. I have also tried the Telefunken ECC88 on the C8+, but it was only for a very short time.
Reactions: thomask
The appointment to audition Trinity Dac and Formula HXD Dac with SGM Extreme Server got postponed to May 28th.
The owner of the shop who let me audition Metronome has high opinion about Trinity Dac.
Thus I am also curious how Trinity Dac sounds.
Reactions: christoph
Thanks for sharing your experiences :cool:
Reactions: thomask
Maybe he is more sensitive to “synthetics” than you are...just an alternative explanation rather than him being so unlucky...
Depends on the tube quality and of course the circuit in which it is used. IDHT tubes will have a different harmonic flavor (or lack thereof) but can be just as transparent.
Reactions: thomask
Driver Complement:
Sensitivity:
92 dB
Impedance:
Frequency Response:
20Hz to 45kHz
25 to 500 watts
Wiring Methods:
Dual binding post
Dimensions:
68" high (178 cm)
14.5" wide (37 cm)
17" deep (43 cm)
Weight:
Hello Thomask,
Thanks for sharing!
I listened to the Dreamplay transport+dac in Hong Kong before. They are super musical and involving!
However I think the title can be a bit more accurate if it were : " If you still spin only CD, ... ".
There are several top universal tranaports in the market which may be as good.
Thanks again!
Reactions: thomask
