So it turns out the 4 amp boxes are actually two power supplies and two power amps. One power amp feeds an entire channel i.e. two panels.
You can feed each channel with its own power amp if you like i.e. 5 amps per channel.
The crossovers are passive. You can use an flat connection, or a plus or minus 1 DB connection for the mid range and treble and super tweeter.
The bass connections are for the bass and extra bass panels should you want them.
