The only record damage I have experienced first hand is a supposedly new Benz LPS-MR with a broken/crack-off (partially) diamond stylus I did not see (thought it looked small and was in denial). Carved up the first few grooves on the record immediately on first play.
In any event, many of those old UK Classical records...Decca, EMI have detectable surface noise, even when visually perfect. I can only attribute this to heavier tracking force of the day couple with not exact cart alignment and possibly the make up of the vinyl itself. I will have to see how these records play on the vintage ortofon SPU from the day to see if the surface noise is less than when playing a modern day cart.
I have currently backed off from 4 grams to 3.5 grams (SPU GTE range 3-5g) and like the sound better. This could be a result of a suspension not as compliant as it used to be considering the cart is almost 50 yrs. old.
