That procedure makes sense to me. I am a big fan of protective and waterproof plastic boxes.
I have never seen pin protectors. Is that an aftermarket item you put on the bottom of each tube?
That is some case, Phil!
Yes, Ron, and I like this part best:
"This case is NATO codified and tested to IP-67 (Ingress Protection). You break it, we replace it... forever."
Quote
Maybe you can even drop it from 10 storeys and the tubes will still be safe.
U could try it , put in some old tubes and drop it lol, they will replace the case anyway
Odd regarding your findings of the GE 6550's. I had them in several amps, including classic ARC's and they never did what you described. WJZ always spec'ed these tubes in his 6550 based designs. The ATM2 is a nice amp, perhaps something else was amiss??
Tesla Vrsovice KT88, now the EAT KT88. Amazing sound the best 6550 or KT88 I ever tried. Horrendously unreliable filaments used to break all the time on the Vrsovice version. A real pity - nothing else came close - anywhere near close. Next best the Tung Sol 6550 but still a big gap between that and the Tesla. To counter and earlier post I hated the GE 6550. In my Air Tight ATM2 it just threw sound all over the place in a really imprecise manner. Which just goes to show how opinions can differ in valve land.
If they have solved the filament problem without affecting the sound on the version now marketed as EAT it will be killer.
A couple of weeks ago I heard a new ATM2. Loaded with KT88's. Was producing a very good sound matched up with baby Serblin's. I have not heard the ATM2 with GE 6550's, but what you describe would indicate that the GE's you had were in some way faulty ( or the amp, as I stated before). Because of their vintage, I have heard a lot of GE 6550's that are way past their prime. While the GE 6550's were a superb tube and very durable, they have a life like all components. When the GE's begin to fail, they certainly can sound as you describe. (Luckily, IME, they don't go volcanic on you) How old were your GE's when you heard the issues?
NOS. Flashing was excellent looked brand new.
Please accept they just didn't work in the Air Tight. Its long gone now and irrelevant.
It is maybe deeper than that, though. I have tried a lot of GE valves - quad of 211s, a quad of 6550s and quite a few small signal valves. I never like them no matter how hard I try because they have never proved the best option. Though the GE 211 really isn't too bad, it simply doesn't come close to Amperex 211s.
