Very cool. The step up from the D1 Dual to even the Monobloc DAC is very substantial. I think you would be enamored with the Twelve.
D-1 Server plus D-1 monobloc DAC with Symposium rack and platforms.
This seems like an outstanding product. Can someone please explain the value added by the Server? I understand the value of the Reclocker, but I am missing what the Sever does to the audio signal to improve the quality of the sound.
Is the server able to present data to the dac to ease processing?
Vincent's server has the reclocker built in. The Server is absolutely world class and a great addition to the Totaldac DAC's. Really is a must!
paolo response suggests yet another reclocker after the Totaldac Reclocker. Vincent offers a System Twelve that adds yet another reclocker after the server reclocker, and if you do this, an improvement is realized yet again. I believe Fish07 has this configuration using the Monobloc DAC's.
Fish07, that is a beautiful rack man. Symposium stuff is no joke and really works. What footers did you use to couple to the Symposium platform's?
Thanks. But what does it do? Why is it a must?
The Server? Because it sounds absolutely incredible. It is also "tune-able" with image file changes. I can't see it not working with any system. The degree to which it bests any other digital source I have tried here is not subtle.
The reclocker is not a fix all type thing... More of a refinement. The digital source still matters quite a bit.
Thanks. What else have you had in your system, Paul?
For the demo in France we used our music, (not necessarily well recorded, just stuff we liked,) on both the d1-server and my partners MacBook Air running on battery with Aurdirvana using my totaldac USB cable (3.5m - I'll come back to that in a bit), the d1-server was connected to the DAC via AES. Both these feed a d1-tube-mk2 DAC, Voxativ 845 (I think) power amps and those huge speakers pictured on his site.
do you mean: the MacBook Air connected directly to d1-tube-mk2 DAC?
If, so, to respect the same configuration, why do you haven't connected the MAC USB output directly to the USB input of Server?
I have the Reclocker (which is included into the Server) and this is a great improvement to the already great D1 Dual DAC.
OK, not sure what you are saying caliaripaolo, but just to be clear, I wanted to know if the server was better than a Mac when feeding the same DAC.
The MacBook Air was directly connected, via my USB cable, to d1-tube-mk2 DAC.
d1-Server was directly connected,via AES, to the same DAC.
They were not connected at the same time, we switched them manually whilst playing the same tracks.
I was not really interested in feeding the Mac into the d1-server/reclocker.
I hope this helps make it clearer?
Well, a d1-server is just a reclocker with a CuBox mini computer encased in a metal box inside. And the Cubox is connected to the reclocker externally via a d1 USB cable. With the Mac directly feeding a d1 DAC, it's missing one level of reclocking compared to the server setup. So the Mac is at a big disadvantage and your results is not surprising at all.
Currently I'm feeding a d1-tube Mk. 2 with a Mutec MC-3+ reclocker instead of a Totaldac reclocker. Mutec is a big advocate of multiple reclockers in series. There are guys in Germany that has 4 levels of Mutec in a row. My plan is to wait for the Mutec MC-3+USB to come out, put that in front of my existing MC-3+ and perhaps add a 10MHz reference clock when that comes out eventually. And most probably I'll assemble my own Cubox in front of the USB input. If I recall correctly, there has been recent mention in French forums of other mini computers sounding better than the Cubox. Will be following that development.
...With the Mac directly feeding a d1 DAC, it's missing one level of reclocking compared to the server setup. So the Mac is at a big disadvantage and your results is not surprising at all...
