Kharma Veyron
boonyarat
211
196
428
Bangkok , THAILAND
The Kharma Enigma Veyron System will come with 4 Monoblock Power Amp , Pre-amp , 8 units Subwoofer , DSP , Power Distribution ,.....:eek:
LL21
14,411
2,509
1,448
What is interesting...is that it is smoothing out and starting to look like an Arrakis. Instead of 2 front-firing woofers, the Arrakis has create 2 separately angle side chambers for dual 15" woofers. I have auditioned them in HK, and remember thinking I would love to have a pair of matching Rockport subs to just FILL the space. It was a remarkable experience in any event, but that enveloping sense that comes from endless bass (dual bass towers, etc)...is just something special for bass freaks.
...and it seems like that is what Kharma is suggesting here...
boonyarat
211
196
428
Bangkok , THAILAND
KHARMA ENIGMA VEYRON SYSTEM:)
FrantzM
29
405
How much? :b
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
How much? :b
Seven figures for sure. Unlike $250K amps, I see seven figures worth of "value" here, in terms of design and build cost, considering extremely small production runs. Ironically, $250K amps will be selling in far higher numbers, not for lack of people that can afford to throw a mil at their speakers (the same crowd that is buying the $250K amp), but for lack of people that are both rich and serious enough about their audio hobby to build the type of room needed to accommodate this type system.
Mike Lavigne
Apr 25, 2010
12,468
11,365
4,410
the concept for the Veyron is similar to what Von Schweikert is doing with the VR111XS (which is similar to the Evolution Acoustics MM7's) except with adding DSP, each subwoofer in a separate cabinet and adding monoblocks.
i suppose the idea of separate subwoofers and dsp is to allow for separation of the subwoofers for best room integration. my point would be that anyone with this type setup would have a custom room to begin with, and would not want subwoofers everywhere asthetically. a separate bass tower instead of separate subs would allow for time alignment for optimal waveform launch. seemingly difficult to do that with 8 separate subs.
i wonder if these monoblocks also are class D like the other Kharma amps?
knowing Charles Von Oostrom i'm sure the fit and finish is over-the-top.
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
This would be a huge difference, because I assume running through a DSP involves digitization of an analog source signals, which would be a cardinal sin to purists......
Mike Lavigne
Apr 25, 2010
12,468
11,365
4,410
while i agree that that is an issue......the megabuck Asian markets this is aimed at are not as sensitive to that issue as more rabid audiophiles might be.
they like great sound, but they love bling bling.
the guy stroking the check for this is likely not at your monthly audio club meeting.;)
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
The upshot is you can probably save yourself half a million by buying just the towers, getting a SOTA digital crossover, (potentially with DRC), and use an array of JL Gothams (or equivalent). Big compromise on the aesthetics though....
Mike Lavigne
Apr 25, 2010
12,468
11,365
4,410
yes; but the whole idea here is that it's a plug and play system where the dealer sets it up and the buyer does not have to decide about synergy, he just says yes. then he changes tracks on his (likely) CD player or server and adjusts volume. it's that simple.
another 'system' like this, but maybe more for the more esoteric audiophile is the full-tilt boggie big Genesis Dragon with the Genesis amps and crossover. Gary avoids dsp and uses a bass tower instead of 8 subs. Genesis does not build their own preamp, but i know Gary has his favorites. but it does eliminate the customer from having to think about amps and set-up.
these type systems are aimed similarly.
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
Probably, but the chances that this Kharma dealer happens to be an expert in DSP/DRC and mains / sub integration are pretty slim. I would say getting say a 16 channel digital Trinnov processor with digital in/out, and using an array of SOTA dacs + and "commodity" subs AND have the system setup and calibrated by someone that does this type of project for a living (typically in complex HT applications), will get you better results than getting some Chinese ultra expensive audio gear dealer to set up an all Kharma system. Moot point, because the Asian prospective owner of this system would probably rather commit hara kiri that suffer the humiliation of taking this plebeian approach.
Mike Lavigne
Apr 25, 2010
12,468
11,365
4,410
that system would be set up by Charles Von Oostrom.....not a dealer.
i owned Kharma Exquisite Reference speakers for 4 years, and spent time at a few audio shows with Charles, the owner/designer of Kharma. Brilliant guy, and his products are outstanding if a bit over priced for most markets. if Charles designed dsp into his system then i'd bet he has got a serious handle on it.
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
OK. That makes sense. Never underestimate the Dutch - very quick learners.
XV-1
3,591
2,573
1,860
Sydney
Is it just me, but do those photos look super imposed or fake?
It does not look like a real room.
LL21
14,411
2,509
1,448
agree...it looks like a CGI to me.
