In keeping with the theme of this forum: What's the best vibration isolation solution? Where vibration isolation is used, how is the effect measured scientifically? What is the subjective effect?
I have your book Ethan. Thanks. From your answer I gather that my new tube preamp and amp, and my Sony HAP-Z1ES will not sing at me or jitter or flutter my bottom if I just put them on a standard rack at some rational price?
P.S. My cat is a Maine Coon named Ben, his brother from birth was Jerry who we lost a couple of years ago after a 10 year battle with diabetes.
I'll skip the subjective part of your question and address only the science. First, the only devices I'm aware of that benefit from isolation are turntables and, less often, loudspeakers.
--Ethan
With all due respect, the performance benefits of vibration attenuation under speakers, CDP's, preamps, and amplifiers is so obvious (and totally audible) assuming your system is reasonably transparent. To claim otherwise is silly.
As Mike stated, you may need to experiment (listening tests) with different devices to find the correct product(s).
Our philosophy is to isolate every component in the system, starting with speakers, then power related (distribution, conditioning, etc), then components with transformers(amps, etc), then sources. Try locating isolation under chassis areas with transports or other internals that generate a lot of vibration. Experimenting is key to achieving best performance.
John
Is that in order of greatest benefit from isolation in your experience?
I agree with that last statement...though I am not entirely convinced I have actually isolated the last component as well as possible. So perhaps I should not be so quick to concur!Yes, the order was developed over time as we better understood where the greatest benefits were consistent in every system. With system to system variability being the biggest variable it took a while to settle on this hierarchy. Usually, when you isolate the last component the system as a whole takes a performance leap forward.
John
Technically speaking when I isolated the 'last component' (my Transport)...I had 16 individual 'isolation sandwiches' for each and every box and component. Even the Transparent network boxes have a slight pad underneath and an Entreq Vibb Eater on top.
That said, I have just added a few more Vibb Eaters on top of the big Wilsons...and yet again, there is greater clarity, transparency, depth of signal and density of note coming thru...obviously it would not be there if the REST of the system were not delivering it...but I think I may not be quite 100% there at the 'last component' stage!!!
Interesting to see Ethan advocating a subjective approach.just have a friend lift your preamp or amp half an inch while you listen with your eyes closed. If you can't hear when the audio device is being lifted, there's your answer. I make this same suggestion to people who ask if their speakers will benefit from isolation. I can't stress enough that vibration travels mainly through the air, so floating audio gear on a pad is mostly futile. I also can't emphasis enough the need to listen blind.
--Ethan
If you're not 100% there, you're to be congratulated for getting well down the road in addressing the key critical areas of audio infrastructure: room acoustics, clean power & signal delivery, and vibration control. I think we're finally beginning to leave the era where infrastructure plays second fiddle to components. Addressing any one of these three areas makes a profound sonic difference; together they let you really hear what you've been paying for. I suspect most untreated systems are capable of sounding much better than their owners have heard.
