Madfloyd,
Did you discuss your concerns with your dealer when the WASP was done?
The WASP was never done.
Madfloyd,
What kind of "click" are you talking about? There are no click adjustments on Alexia.
So was it the step block adjustment on the whole upper module, the front and back adjustment on the upper module, or the front and back adjustment on the tweeter?
Huh ?!? Why not? It's a crucial part of this speakers installation...
Thanks for the clarification guys
With Alexia one of the most important things is to have the 2 speakers at exactly the same height from the floor....
Ian,
This is straight from our Engineering department in response to your question:
Assuming that the enclosure is 2" from the bottom of the woofer cabinet to the floor the set up is as follows:
Upper Array Spike Length: #3
Upper Array Alignment Block Position: 14
Upper Array Alignment Block Step: 9
Tweeter Detent Position: 5
And as always, room acoustics play a role in sound reproduction, so playing with the alignment positions might be necessary. No other speaker system offers the unique ability to adapt to a room by changing driver locations relative to one another.
Ian,
It is nice to get such a direct response from the manufacturer. Ian, please let us know how this works out and whether or not you end up moving the speakers up or back and in or out. I have found that it often takes a lot of listening and repositioning to get the speakers, listening seat and room working well together, but when it does, it can dramatically increase listening enjoyment. It should be well worth the effort in the end.
How would they not be - unlike the Sashas, there's only 1 spike size (if I recall correctly). Do you mean getting the threading exactly the same on the spikes? Could you elaborate?
Measure from the floor to a known point on the speaker. I use the top socket cap screw on the woofer. On initial install I was off 1/4" and couldn't figure out why everything sucked. Made the adjustment by the threaded spikes so the 2 spks were identical and everything snapped into place!
Debby,
Thank you so much for this - much appreciated.
Ian
