Confirmed by you only or someone else also - especially from Devialet?
Can't follow your argumentation. Based by own experiences?
gatomusik - I got home and checked my Aurdirvana preference. Exclusive access mode, Direct Mode and Integer mode are checked. I do not know whether the features are working properly or not. How do you know Devialet does not work with Audirvana with those features? Thanks for your help.I can make Audirvana play through Air2 only by turning off all the best features of Audirvana: exclusive access, direct mode, and integer mode.
However. You wroteI haven't made any arguments so it is unsurprising that you cannot follow them.
Where is this information from?There has been no change whatever in sound quality arising from any firmware update since the D-Premier was introduced over two years ago.
Sound depending on WiFi factors? Or computer software?If you are referring to changes in perceived Air sound quality then these will be caused by external factors - usually WiFi or the computer software.
I did notLooks like Devialet has waited sending out a newsletter until (most of) the problems were fixed. I received one early this afternoon about AIR2.1/fw 6.0.7.
I have owned a D-Premier since launch 2.5 years ago. (Replacing a Krell). Speakers QUAD 2905.
G
Would anyone who knows care to explain how Amarra or Audirvana or whatever works with Air2?
My understanding originally was that these bits of software would not work with Air1 and that it was Devialet's design to get a "pure" iTunes file without any processing, modification or interference from the iTunes and/or Mac system.
I presume this remains Devialet's aim but now, with the virtual sound card, it seems that Amarra, etc, can be accommodated.
So presumably you chose Devialet's preferred architecture (iTunes/Air2) or another (iTunes"+"/Amarra/Air2"-")? What are the technical gains and losses?
Gorkitek: You mention using the D-P with Quads 2905. I am contemplating to get into "Quad country" after a stint with moving coil speakers. I had Martin Logan Sequels years ago and liked them very much.
How well does the D-P drive your Quads? Do you think the 2805 would be a reasonable choice? My problem may be space, as the 2905s are 140 cm high.
I had Quad 989s for 5 years and Quad 2905s for 7 years but eventually decided that they dominated my room too much
Getting a moving coil speaker that is close to the Quads is tough and probably more expensive than the Quads themselves.
When I created a new file for my D-Premier using the new Configurator, I noticed that the dimming function was no longer available. With the file created by the old Configurator, the display dimmed completely once play was started, and lighted up and dimmed again if the volume on the remote or remote app was readjusted. I miss that dimming function. Have I overlooked something in the new Configurator? There is a tab above the new D-Premier Configurator to adjust brightness, but it only seems to adjust the brightness of the standby mode display.
