Recently acquired a Sony TA 4650 VFET integrated to use as a phono stage in my vintage Santa Cruz system. Also acquired a Yamaaha C70 preamp to try, both cost a total with shipping about 400 for both units.
I used a Sony TA 5650 VFET in my main system for about ten years from about 1978 to 1989, until it got scratchy and Sony told me it couldn't be fixed. No internet in those days for info. The amp section blew, then the preamp, so without any repair means I chucked it after hauling the carcass around for a few years.
VFET is the only transistor ever created that a died-in-the-wool toob-head could ever abide.
Some Japanese high end designers are re-inventing VFET in new build SIT amps (static induction transistor=VFET) and Nelson Pass has a couple of stereo 10 watt single ended SIT amps for 5k/10k(monos) respectively.
I looked at the circuit diagram of the TA 4650, and it uses a small signal VFET in the phono stage, connected to a single FET flat amp then to the VFET push pull output amplifier stage. The push pull VFET amp stage is connected directly to the headphone jack by an impedance matching array of resistors.
Using a headphone adaptor to RCA jack, this turns the TA 4650 into a volume controlled VFET phono amp. This would make it the only VFET phono amp I am aware of, with the exception of its big brother the Sony TA 5650 with the same circuits, and possibly the Yamaha C1 vintage monster.
Using the integrated in this way from phono input to headphone output gives about a 65 db gain, no need for a head amp or input coils. Resistor loads could be added at the input if desired,or the tone controls could be engaged to add another single stage FET amp for tone contouring. The TA 4650 is extremely quiet as well, no hiss.
It sounds a lot better than the Yamaha C70 phono head amp, with the Yamaha C70 itself is one of the best vintage solid state phono stages ever produced.
Sony claimed that the VFET had the output characteristics of the 2A3 vacuum tube with a triode like response. I have to admit, they did not exaggerate much.
The VFET unit as a phono and headphone amp has uncanny transient response, vast 3-D sound staging both laterally and depth, and a vivid, natural sounding tonal character. It is non-fatiguing to listen to.
Bettering the outstanding Yamaha C70 phono preamp is no mean feat.
My unit was mildly refurbished already, but I replaced the notorious VFET "death diodes" myself and used the amp bias setting at 60mV rather than the recommended 75 mV, which allows for warm but not hot performance. I can't tell any difference in sound quality.
Best phono amp I have heard short of the uber expensive LCR tubed types, and as stated, when used this way, one of the few VFET phono amplifier in existence that I know of.
Using it with Sony PS X70 vintage DD turntable/arm and Allnic Verito cartridge.
Cool.
Cool.
