transparent Gen 5
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
I was in the market for a balanced Transparent Reference MM2 cable between preamp and DAC, planning to pay $2,000 max (waiting for one to show up on audiogon). I Gen 5 was just listed for $3,500 (MSRP $5,500). (A) You think it is worth the extra $$$? (B) is $3,500 a fair price? These cables have just been out for a year or so, so I don't know what they trade for as percentage of MSRP.
jfrech
2,156
751
1,160
Austin
The Gen 5 versions are a bit better. That said, MM2, is no slouch. Have you called a Transparent dealer? They have a certified used program. This allows you to get the tuning service for free as equipment changes...I suspect you could get your MM2 versions for around your 2k price. As for the Gen 5 price...it's just below 70% off...which is what Transparent would trade that cable in for a upgrade. Not sure you'll see the Gen 5's much lower given they are pretty new on the market...
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
Thanks. I'm a little on the fence about this transaction. I actually offered $3,000, and will probably stick with this. If the seller does not bite, I'll hold out for a used MM2 to show up....
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
Seller came through for $3,000. Turns out he is a Nobel prize winning astrophysicist. How cool is that. These better sound good.
bonzo75
22,639
13,668
2,710
London
Did you check if he was an objectivist or subjectivist?
Reactions: gian60 and wfojas
jfrech
2,156
751
1,160
Austin
Nice !! On the price... Great to see a Nobel prize winner as a audiophile !
andromedaaudio
8,485
2,835
1,400
Amsterdam holland
And they buy those high $$ cables , now i am really doubting myself lol , the world has gone mad :D
anyway congrats , ... do they sound different ???
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
I won't be able to tell. First, I need to get my new preamp in (the forthcoming PS Audio) first. Second, I won't have a reference to compare, because I am going DAC direct now.
andromedaaudio
8,485
2,835
1,400
Amsterdam holland
I see , i m personally more of the change one at a time approach , because its otherwise pretty hard to tell what made what sound differerent , imo
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
True. But if you have a greenfield situation and insert a preamp into a system where none existed before, there is nothing to change. You just have to pick a cable.
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
Upon reflection, I am using a run of Reference MM2 between DAC and amp. I can replace this with Gen V for a direct comparison between cables. This should be fun. Stay tuned. I'm not expecting much difference to be honest, but I may be surprised...
jfrech
2,156
751
1,160
Austin
My vote, from my experience, is a mild surprise - same character just more of what the mm2 provides. Looking forward to your thoughts.
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
More good news on the Transparent cable front. As I was shopping for the IC, an MM2 SC showed up for $1,400 (at least $1,000 below value). I scooped it up immediately and resold in 4 hours for $2,700. I've been buying stuff on audiogon for well over a decade, but never came across such an opportunity....
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
Compared the MM2 against the Gen V (between DAC and poweramp). Gen V appears to be faster and more detailed, the MM2 sounds somewhat warmer. I could easily live with both.
LL21
14,430
2,517
1,448
Good to know. Thanks for that...if you have the time to put a few more listening notes, that would be fun reading.
jfrech
2,156
751
1,160
Austin
+1. I found its one of those things that keeps sneaking up on you. I would not disagree with edorr, but suspect a little more awaiting in gen 5. That said. Mm2 is still outstanding totally in agreement
Cincy2
117
187
220
Tampa, Florida
Newbie forum user here. I just discovered this community and feel I can add some perspective on this particular topic. I purchased my first Transparent cable in 1993 and have been a customer ever since. I've been through their entire range over the years. Currently have Opus MM2 speaker cables and Ref XL or equivalent on all other interconnects, clock cables etc. Each and every time I paid handsomely for an upgrade, I was rewarded with an increase in performance. I don't think about it any more, just get the upgrades when available. My SC's are headed to Maine on Saturday for an upgrade to the Gen 5 configuration. It is pretty pricey but I know from 20+ years of experience that it will be worth the price of admission.
Cincy
jfrech
2,156
751
1,160
Austin
Cincy
Hi Cincy, I did the MM2 to Gen5 Opus SC upgrade last fall. You won't be disappointed :) Very well said above in your quote !
Also...Hopefully you can try a Opus Source power cord soon...maybe one on your DAC to start...careful...one bitten....you know where this is going !
LL21
14,430
2,517
1,448
Cincy
I am with you Cincy...nice system by the way! Congrats on te Magico M3!!! I started with Transp Ref speaker cable (2nd hand) in 2005 or so...it was a Ref (the same generation as when XL first came out), went to XL MM2 via an interesting trade that was a bit too good to pass up and now to Opus Gen 5. I am contemplating upgrading my RefMM2 ICs (which sits just below the old Opus MM2). We shall see.
My observations are entirely consistently with yours it seems, and with JFrechs.
