Science Thread: Review of Audioquest Jitterbug and Uptone Regen USB Conditioners
Apr 3, 2010
16,022
Seattle, WA
I don't think that is necessarily what is occurring here. I'm not trying to defend subjective listening tests, but for "measurements" to be useful in assessing anything one has to be measuring the "right" things....
I am all ears as to what you think the right thing is. I measured three things:
1. Comparison of USB power coming out of my computer compared to what comes out of these devices.
2. Noise floor of the analog output of the DAC to see it has gone done as a result of filtering and or regeneration of the bus.
3. Level of spurious distortions and noise when playing a 12 Khz signal.
Please explain why these are not useful or "right."
, one has to be measuring them in a repeatable and meaningful manner and one has to be able to interpret the measurements correctly.
I have repeated them and did that one more time this morning in response to testing with longer cable. Results are consistent. Why do you say they are not repeatable? Based on what data?
As for interpretation, I did that too. I explained that while these products seemed to have degraded measured performance some, I consider them to do nothing audibly. Happy to see someone challenge me and explain otherwise. That is what we ultimately want, right? Whether measurements back output of the DAC changing?
Many posters are pointing out that in this case none of those requirements have been met.
Many posters? I see a couple of people putting forward arguments. None have remotely been compelling for simple reasons I have explained and continue to explain. Either something changes the output of DAC or not. I have data that shows no improvement came out of the DAC. No data has been put forward to say otherwise. And no argument remotely sticking that we should do some other test like staring at eye patterns. When was the last you cared about the eye pattern of USB bus? And if you did, what do you think of Paul Miller showing almost no difference?
What was repeatable about JohnW's measurements? Do you know what computer he used? What USB port? What cable? Nothing, right? I provided all of this detail.
And I'll repeat again, there is nothing "scientific" about this forum so far; no scientists have participated and no accepted scientific method is being used. If you want to be honest call it the "measurement forum", but also be honest about the breadth and depth of ignorance present.
I am following the standards practiced in professional audio engineering industry. If you come out with a black box that sits before the DAC and claims to make it sound better, they will immediately ask you to show that the electrical signal on the output of the DAC changed. None will care one bit what happened on USB until you demonstrate this point. And that is the test I did. You can call it whatever you want but improper it is not. It is core to analysis of such products.
Apr 3, 2010
16,022
Seattle, WA
I'm not sure what the "outcome" is here; perhaps you could state it again. As far as I can tell, you made some measurements; no meaningful correlations were made to their relation to potential audibility (or lack of). Nothing "scientific" about that, any more than someone else's subjective impression that there was (or wasn't) any audible change or improvement with the DUT's. It doesn't become science until you have used your data or observations to formulate a hypothesis, devise and perform an experiment to test that hypothesis, and then analyze those results. In today's world, that must also be followed by peer review and reproducibility, because while you may think that your experimental design and analysis of results (conclusion) is appropriate, your scientific peers may disagree.
My peers would all agree with what I did as I just wrote to you. If you say sound changes, they want measurements that show sound changed electrically. My measurements show that only a tiny amount of change occurred with these devices but in negative sense, not positive. I explained that such negative change to be too small to be audible so the net result is that the device does nothing audibly.
If someone has other measurements, let's see them. If you don't have that, and can't critique the work based on accepted industry standards of engineering, then there is nothing to discuss.
BlueFox
1,075
Silicon Valley
Perhaps looking at the DAC output with something more than a 12Khz signal might be useful. Maybe a sweep from 20-20Khz might reveal something. Don't know, just a suggestion.
Apr 3, 2010
16,022
Seattle, WA
I don't expect it to be revealing but sure, when I get back from RMAF I will run that too. Thanks for the suggestion.
Nov 27, 2013
217
Perhaps it would be better a pink noise with complex envelope and high slew rate, at least double the most difficult and dynamic track it exists :cool:
Sep 30, 2015
3,131
Playing around with different power supplies connected to my audio server computer, I can definitely hear the difference when a beefier supply is used when listening to my DAC via USB. Especially in the bass department. I think the main reason so many claim to hear positive results with the Regen is plainly because of the dedicated supply providing solid power directly to the USB chip very close to the DAC input. Even if other distortions are added, this extra boost catches people's attention.
Although there's been over 1700 satisfied Regen users, the % of satisfied users among the professional crowd seems to be much smaller.
Let's not forget "my pet rock" made the inventor rich as well.
jkeny
3,427
Ireland
This is incorrect. The DAC has a PLL which filters jitter. If you measure the jitter prior to that at the clock input, you will be misrepresenting how much jitter will appear in the output of the DAC.
Again, Amir, I believe you are confusing matters. The DAC you used for testing was the Merdian Explorer - what PLL does this use?
Let's clarify what I believe Alex is talking about - there are 2 distinctly different clock domains in any asynch USB device - the USB clock (12MHz or multiple of) & the audio clocks (usually a pair - one for each speed family) which are the ones where jitter matters. Jitter is only important at the D to A conversion step & the audio clock is directly used in this step (not a PLL derived clock). What Alex was suggesting is that the jitter at the audio clocks input to the DAC chip is indeed the one that should be measured - it will directly affect the output from this chip. Now could this output be corrupted by the output stage after the DAC chip - yes it could. What you are measuring is this downstream output (which will differ from DAC to DAC) & looking for signs of jitter here. Does Alex's suggestion not have merit? Furthermore, to do this, you are using a jitter test which is somewhat imprecise & general.
Seeing as the main element of change in the USB signal seems to be low frequency fluctuations (as per JohnW's measurements), should you not use a jitter test with some more sensitivity to close-in phase noise?
It is like saying let's ignore a car has suspension and then see how good it rides. The car has suspension and you can't judge its ride without it. Same with the DAC.
Sorry, but it's nothing like your analogy - there is no suspension (PLL) in operation in the DAC unless it is receiving SPDIF signal. What Alex is saying, to use your analogy, is to measure the bumpiness of the road because you have no suspension (PLL)
Importantly, what we hear is the analog signal of the DAC. We don't listen to the clock. We have hard enough time convincing people to pay attention to the measurements of the DAC waveform. How would it then be a better approach to then try to get them to understand correlation between some digital clock source and audio???
So no, we don't deviate from industry standards such as measuring the analog output of the DAC. It is the right thing to do.
Now if you are a designer, sure, you instrument the DAC clock jitter. But we are not. We are customers and care about what comes out of our DAC.
I'm sorry, Amir but there are mixed messages here - are you doing a consumer report or a technical investigation - you seem to be flip-flopping between the two?
When a device is being analysed, it's the output of the device that is first & foremost of interest - do you analyse a turntable's performance by looking at the output from the speakers?
Do you see any of the prior "industry standard" investigations into the Regen only looking at the output of a DAC when analysing these devices?
rbbert
Active Member
Dec 12, 2010
3,423
Reno, NV
The name of the forum is "science thread"; if you actually mean "engineering", or "measurements", then change the name to the appropriate one; your choice. As "site founder and administrator", you should have higher standards. As I posted before, engineering is not a science.
As far as "peer review", read post #62 again. As far as reproducibility, I must have missed that. Who else has reproduced your results?
jkeny
3,427
Ireland
Whatever PLL is integrated in the PCM5102 DAC chip it contains.
Have you done any research into the PCM5102 DAC chip or looked at a datasheet before making the above statement?
Please let's not further demean this thread by just saying anything that comes into your head - it has already reached a fairly low level of technical & scientific endeavor.
jkeny
3,427
Ireland
Why? The science says if you have a high fidelity DAC with its own power and asynchronous and isolated USB input, none of these devices are useful or do anything at all. USB is being used simply to carry data much like it would to a printer. Now we could leave it at that and be done with it. Certainly vast majority of professional engineers in AES and such would have laughed at any investigation further than that.
Sorry, Amir, can you tell us how you have a galvanically isolated USB input on the Meridien Explorer DAC or any modern DAC that operates at USB 2.0?
We have the claim of a PLL on USB input & now the claim of "isolated USB input"
As we can see above, there is so much loose, unscientific assertions & definitions being made in this thread that I believe it should be closed down as it is doing an injustice to the name of science & attracting those who think it's fine to say whatever comes into their heads without research or investigation into what they say simply to score points or incite a reaction
3
38
Robert,
I have posted the bolded sentence several times, even quoted the ABET definition of engineering without any success. Unfortunately most of the never ending threads are just caused by a natural confusion concerning the definition of measurements and science.
IMHO it seems now that this thread was meant to be a measurement thread, but once Amir posted in the OP his informal subjective findings and his conclusions about the value of his garden rocks he opened a Pandora box. The gate was open to the unfortunate subjective / objective wars that followed ...
CSI2130
2
That's a lot of criticism there mr jkeny.
Ok, as you seem to be so informed on this subject could you provide some of your measurements which show the audio clock phase noise being affected by the USB data jitter? Followed by measurements of the improvement with the regen or jitterbug.
Could you then post some measurements of this manifesting in the dac output and improving with regen attached? I assume you can test this sort of thing as you are a dac manufacturer?
Thanks
jkeny
3,427
Ireland
Thanks
As I said, "attracting those who think it's fine to say whatever comes into their heads without research or investigation into what they say simply to score points or incite a reaction"
This thread is now just a magnet for trolling even attracting new trolls
CSI2130
2
Excuse me! from your posting you appear to present yourself as someone knowledgeable on the subject. I would have thought that you would therefore be able to present some scientific information that that supported the proposition that these USB devices provided genuine technical improvement.
I am certainly not going to stoop to your level, I asked a reasonable question and get insulted by return. It is clear that you don't understand the irony of your signature.
Good day mr jkeny
Apr 3, 2010
16,022
Seattle, WA
Sorry no, you are confused about the conversation. A generic comment was made that one is a fool to measure the jitter on the analog output of a DAC. There was no conversation about the specific DAC I am using. I commented that the DAC can have a loop filter in its PLL and no way can you throw that part out and pretend that you measuring the jitter that is coming out of the DAC. It would be unfair and improper to disadvantage DAC manufacturers that way. It would make a DAC with super jitter reduction on its clock input the same as one having little to none.
Importantly, and I am repeating myself again, what we care about is what we hear. If I measure the clock pin to a DAC, how on earth would you correlate that what comes out of the DAC when you don't know what level of filtering is being done? Unless you are a DAC designer, it is never, ever important to look at the jitter at clock input. This is why no one measures it that way in reviewing equipment and why every engineer would take you out back and shoot you if tried to represent the jitter in a DAC system as what goes into the clock pin.
As to your specific question, as noted the PCM5100 series DAC has internal PLL although it can be disabled. I have not looked at the schematic for the DAC I used so don't know which mode they are using. But again, it doesn't matter. I was addressing the generic comment that measuring jitter on the analog output of a DAC "is a joke." If you believe that is the case, please make your case clearly and we can address it.
Apr 3, 2010
16,022
Seattle, WA
MOD: this is the last warning. This is not a forum where we speak to each other this way. Continued argumentative rants will not be tolerated folks.
John, I am not responding to most of your posts because they are emotional rants with technical terms thrown around. The thread has a set of measurements. If you have questions about what they are, we can discuss them. If you don't, then that is that. You can present your own measurements or anyone else and I very much welcome that. If you don't have that, or ability to make such measurements, then you are not qualified to challenge them left and right with technical theories you have not confirmed.
