My 2015 upgrade is to replace two Zitron Anacondas with Sigma HC cables used for my amps. Since these cables are from the wall to each amp's Cyclops, they have the IEC 19 connection. I then wanted to use the Anaconda to replace the Python that goes from the Cyclops to my amp. However, I just remembered the amp has the 15 amp power connection, so the Anaconda will not work, and I do not want to use an adapter.
Is it possible to have the Anacondas re terminated with a 15 amp plug?
