DNT Internet Radio IP Diamond 20314 No. 21304F4002621
I have now owned my DNT Internet Radio for about 5 years, and suddenly have the following problem.....
When I start up the radio, I receive the last programmed channel as usual, which works fine...... immediately, using the remote control I can change the programme to any other programmed station, which is normal.
But after a few minutes, I cannot change anything (although the initial radio station transmits normally) - not only is the remote control dead, but none of the buttons on the radio work. I can only turn off by withdrawing the power supply plug. To change the programme, I have to re-insert the plug, and afer the normal booting, IMMEDIATELY change to the required programme. The buttons and remote control all work – but only for a short time, and then are all dead.
Is there some sort of digital problem – can I re-set factory settings or something?
Thanking you in advance
Robert Schedler
Alsace
France.
Robert Schedler
Alsace
France.
