My recollection is Mephisto wins but I would not wager on that based on my memory.Thanks guys, that does help.
How is the noise floor on the Mephisto compared to the S250 ? i know CH M1 is very very low.
It seems that you have been investigating the different options for your system since ages. I hope that one day you will finally settle and enjoy your new system.
Measure twice..cut once...I support your careful approach. It has taken me years sometimes to wait for the piece I wanted even when I knew what it was. But the piece was right, and the price was right. And I have never looked back.Just have to be patient in life, things will happen.
Gryphon Class A has many strengths, S/N however is not one of them. The Mephisto is rated at around 80db, which is solid tube amp level. CH is an order of magnitude better in this regard. That does not necessarily correlate with the sonic outcome of course, speaker matching is much more critical. Personally I am a gryphon fan, having owned the Antileon Signature for almost 4 years, fabulous amp!
Good luck with your search.
Thanks for that...I just looked up the new Mephisto (105db SN Ratio)...and just realized that I have only heard the original Mephisto 200watt/channel. So my comments apply to that one. I apologize...as you can see, I admit that I have been so happy with Gryphon, I have lost touch with some of the other amp manufacturers and did not realize the Momentum Stereo had received an upgrade.Gryphon Class A has many strengths, S/N however is not one of them. The Mephisto is rated at around 80db, which is solid tube amp level. CH is an order of magnitude better in this regard. That does not necessarily correlate with the sonic outcome of course, speaker matching is much more critical. Personally I am a gryphon fan, having owned the Antileon Signature for almost 4 years, fabulous amp!
The Momentum Stereo original which I heard had a S/N Ratio of 90db A-weighted vs the Mephisto of 83db A-weighted.
Hi...apologies. I do not know the technicals...other than the obvious.Do you know what upgrades have been done to the present Mephisto 175 watts ?
Did they use the same newer parts as the Antileon Evo ?
You should listen to the Heisenberg - you might decide to make it within budget! In my system I put them ahead of a pair of M1.2's.Well i will most likely purchase Borresen 03s which are highly resolving speakers just like my previous Thiel CS 3.7s but less bright.
The Mephisto should be a good match with it's physical bass and organic sound.
CH M1 might sound a little thin on the Borresens as opposed to the Mephisto, just a guess.
Dag S250 beeing musical should do well with the Borresens.
I would have loved to put the Audionet Heisenberg in the battle but it's not within my budget.
Sorry Thieliste...I just realized why i created all the confusion! I meant to say I heard the original MOMENTUM (NOT MEPHISTO)!! Yeesh what a dumb mistake. There is ONLY ONE Mephisto model. There have been TWO MOMENTUM models by D'Agostino.Thanks for that...I just looked up the new Mephisto (105db SN Ratio)...and just realized that I have only heard the original Mephisto 200watt/channel. So my comments apply to that one. I apologize...as you can see, I admit that I have been so happy with Gryphon, I have lost touch with some of the other amp manufacturers and did not realize the Momentum Stereo had received an upgrade.
One of the audio dealers who kindly came to install the Gryphon Mephisto (not Gryphon dealer...he was doing a favor helping my dealer) sells the Heisenbergs and was raving about them. He loved the Gryphon too, and had years of experience with them...but we spoke at length about his impression of the Heisenberg, and he had only superlatives to say about them. He did not appear to be in sales mode given that I had just acquired the Gryphon Mephisto...i genuinely found him enthusiastic about the Heisenbergs...and he clearly had been successfully selling high end audio for many years.You should listen to the Heisenberg - you might decide to make it within budget! In my system I put them ahead of a pair of M1.2's.
Hi...I just realized...i totally mistyped my earlier quote...i meant to say i had heard the original MOMENTUM STEREO (D'AGOSTINO)!!! Not MEPHISTO. There is only ONE Mephisto. There obviously have been 2 Momentums, the S250 being the updated model. Sorry for all the confusion!Do you know what upgrades have been done to the present Mephisto 175 watts ?
