Cone break up , ... tweeter ringing ???
Jan 23, 2011
3,857
Amsterdam holland
#1
As steve proposed a thread about .. cone break up .
First simply explained how the loudspeaker works .
The music signal is a varying alternating current/voltage , this creates a changing magnetic field in the voice coil .
Together with the permanent magnet in the speakerunit this is "" the motor"" of the membrane .
The voice coil gets attracted and distracted/reppeld to/from the permanent magnet.
A LS unit is optimised for a certain freq area in the case of a (metal )dome tweeter for example 2,5 khz -20 khz http://www.seas.no/index.php?option=com_content&view=article&id=76&Itemid=100
this graphic shows a metal dome with break up at around 20 -30 - 40 khz , metal can break up quite drastic but the units keep getting better , berylium is an example http://www.scan-speak.dk/datasheet/pdf/d3004-664000.pdf hardly any violent break up there
When a cone breaks up its not able to follow the music signal accurately anymore and starts to make uncontrolled swings .
Same goes for bass units(or mid units) made of hard materials / metal in this case aluminium , they can also break up quite drastic , example aluminium versus paper http://www.scan-speak.dk/datasheet/pdf/26w-4867t00.pdf
http://www.scan-speak.dk/datasheet/pdf/26w-8861t00.pdf
One way of dealing with that is to use higher order filters with steeper slopes , so to make the break ups "" more "" inaudible , another way is to use for example high quality paper units which break up more friendly in general and use simple filters (less phase problems )
Assuming though most people hear nothing higher than 20 khz , so whats the problem :D
Point is you dont want these break ups to be audible , this also the reason there is a specific unit made for a specific freq area .
This is the high freq unit i use at the moment ,smoother than berylium virtually no break up although it doesnt extend as much http://www.scan-speak.dk/datasheet/pdf/d3004-662000.pdf
These are reasons i stepped away from the use of hard materials in LS units.
or this one a ringradiator soft dome http://www.scan-speak.dk/datasheet/pdf/r3004-662000.pdf, although it has a little more break up its a soft dome also thus sounds different then a metal one , also quite extended
Bruce B
Apr 26, 2010
6,555
1
38
Seattle, WA
www.pugetsoundstudios.com
#2
I know my W/P 7 system used to suffer from the ringing. It would create listener fatigue where I could only master on them, without getting a headache, for a couple of hours. On the other hand, I also have Focal speakers with the berylium tweeters and can sit in from of the 10-12 hours doing Post movie work and still feel my ears are fresh.
Bruce B
Apr 26, 2010
6,555
1
38
Seattle, WA
#4
And what about the new alexias , i bet they are very listenable ??
I did 3 mastering sessions in one day and still went in after it was all over to just 'listen' to some more music. Priceless!!
DaveyF
Active Member
Aug 1, 2010
5,617
2
38
La Jolla, Calif USA
#5
Bruce, what you say about the new tweeter in the Alexia's doesn't surprise me at all. IMO, the old Focal driver was exactly as you describe it, I couldn't listen to it for any length of time without getting listener fatigue. With a silk dome, that simply doesn't apply. Kudo's to Wilson for finally seeing the light ( or hearing the "ringing", LOL:D). I have to question why it took them so long to change though. I do think that in some ways they owe their old and loyal customer's an upgrade path to the new tweeter. At a price, retrofit should be accomplishable, IMO.
Site Founder, Co-Owner, Administrator
#6
You would think but I doubt it well ever happen.I wouldn't be surprised as well to see the X2 discontinued at some point in the product line much the same as the X-1 was with the release of the X2
DaveyF
Active Member
Aug 1, 2010
5,617
2
38
La Jolla, Calif USA
#7
Steve, I wonder if enough owners of the old tweeter were to "suggest" or to "demand" to DW and his group that a retrofit be offered and to "suggest" that it could be PROFITABLE to accommodate such a retrofit; that maybe DW would relent and offer it. Just a thought;) Obviously enough owner's would have to desire the upgrade and a) make it worth DW's time and b) co-operate on the request ( probably a lot easier said than done, OTOH one never knows). BTW, are you listening Debby W, LOL.:D
#8
I spoke to DW about that very issue when the speaker was shown initially as a static display at RMAF. I was told that due to changes in cabinet size as well as size of tweeter as well as different crossovers it wasn't doable
I do remember the X-1 Series V update before the X-1 was phased out
Jan 23, 2011
3,857
Amsterdam holland
#9
But still wilson chose not to do it on the x2 , it uses a 1 inch soft dome or soft dome ringradiator at the back , scanspeak iirc .
Softdomes whether silk or not have been around a long looooong time.
So the X2 does have a soft dome already it might take over where the focal starts to get in trouble just under 20 khz, or just ambient i dont know.
Does the xlf has a ambient tw also ?? i ll look it up
Yes the xlf has 2 silkdomes both 1 inch , the ambienttweeter type on the x 2 is not mentioned on the site
j_j
325
In the Rain
home.comcast.net
#11
You can make the crossover or the cutoff as sharp as you like digitally, just don't introduce pre-echo when you do it.
Unfortunately, that is not going to help you much, because if there is a strong resonance in a driver, harmonics generated by the nonlinearities in a driver (and there are lots) will excite the cone resonance anyhow.
And, yes, that's bad.
