2xDSD Playback through PC server to PCM DAC
garylkoh
Sep 6, 2010
5,599
225
1,190
Seattle, WA
www.genesisloudspeakers.com
A good buddy (retired cop) had some spare time on his hands, and did the research to figure out how to rip SACDs.... but as he didn't have many of his own, volunteered to rip mine for practice. I had far more than I expected. Going through my piles of CDs, I also discovered a huge bunch of hybrid CDs/SACDs that I sent to him. Now that I got it back, how to play them all. I have nearly half a dozen DACs, only one of which played native DSD. I've also got lots of native DSD files courtesy of my recording engineer friends.
Enter the Super Audio CD Decoder for foobar - http://sourceforge.net/projects/sacddecoder/
Now, every one of my systems will play DSD files :)
I did a few quick comparisons of a few tracks between the DSD and the Redbook layer, and on every one, I much preferred the DSD converted to PCM. This was on an M2Tech Young DAC.
Mike Lavigne
Apr 25, 2010
12,596
11,689
4,410
Gary,
i've had to read your post a few times to 'maybe' get an understanding of what you are saying here. please correct me if i am missing your meaning.
when you say that you prefer dsd converted to PCM, you mean that you prefer the soundforge plugin for foobar playing dsd files converting them to PCM played thru the M2Tech Young DAC.....to......native dsd files played thru your M2Tech Young DAC.
did i get that right?
if so; have you asked your 'recording engineer friends' whether they have compared playing dsd files thru soundforge/foobar to their SOTA dsd dacs? in other words, does the quality of the dsd DAC change the equation?
thanks. just wanting to make sure i'm following your meaning here.
garylkoh
Sep 6, 2010
5,599
225
1,190
Seattle, WA
I might be wrong, but I got that Gary preferred DSD->PCM rather than Redbook standard, even if DSD has not been played natively.
Correct. As far as I know (may be a newer one does) the M2Tech Young does not play DSD. This set-up is so that I can use all my systems to play the DSD albums I now have (several hundred) without having to go through the pain of converting them to PCM.
I'm comparing the SACD layer to the Redbook layer on Hybrid SACDs - with both layers ripped to my server.
NorthStar
24,305
1,323
435
Vancouver Island, B.C. Canada
-- ...But usually, the CD layer (PCM) of an hybrid SACD is directly derived from the DSD recording, no? ...And it usually sounds better than a straight PCM recording because of that DSD's origin (implementation/recording technique)?
Just as a quick example: All my Rolling Stones SACDs, the CD layers sound much cleaner, more resolute, with better clarity, stronger and tighter bass than all my original Rolling Stones CDs.
...Same with Bob Dylan, and all the rest of the gang. ...Much better remastering sound.
garylkoh
Sep 6, 2010
5,599
225
1,190
Seattle, WA
The layers are usually different - on one particular (Sting) album I looked at there was very heavy compression used on the PCM layer when the two were eyeballed in Audacity. Seems the 'loudness war' only has been affecting RBCD.
That's why I wanted to get the SACD layers ripped, and have some way to play them back.
Orb
3,010
2
Just as well DSD is not universal yet then, because I am sure that layer remaster would also then be shafted with extra loudness-dynamic compression :)
Although raises the point of how both were processed inside the studio for the same album.
Cheers
Orb
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
www.pugetsoundstudios.com
This may be where HD Tracks is getting some of their "HiRez" PCM files
I don't know of ANY SACD layer that has been derived from Redbook. I should know, I've been doing this for HDtracks since '08
There has been SACD layers from 24/44.1 and 24/48 Mostly the BIS label and the rest has been weeded out.
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
I have at least one 88k2/24bit download from HDTracks which has been sourced from DSD. I don't think there's any secret about that - the ultrasonic noise is very obvious.
I've done ALL of HDtracks transfers from SACD at 176.4 and 88.2
rbbert
3,820
239
1,000
Reno, NV
This title is NOT on HDtracks...
Actually, it is, in 24/192 and 24/96. I have no idea how it sounds or measures, though.
rbbert
3,820
239
1,000
Reno, NV
The "Come Away With Me" is one of the Sterling Sound transfers, I think.
I'm not sure why I'm posting about this, I don't care about her music...
