Inserting FULL-SIZE images
muralman1
479
Sacramento Ca
Oh brother. Now you know why I am a Mac Man. I hate rules. I will not drag to paste then. What about the sideways show? Is it too tall in it's vertical position?
Anyway, thank you, Amir.
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
Hey, we didn't write this software :). It is the best of breed but its usability leaves something to be desired at times.
On your sideway picture, I assume it looked right on your computer. If so, then you may have told your photo application to turn it and instead of turning the image, it remembers that it needs to rotate it when it displays. So when you upload the image here, it still looks like it did before. Solution is using a different program on your Mac that really rotates the image.
muralman1
479
Sacramento Ca
The speaker picture was taken with my camera in the vertical plane. When I uploaded it, it uploaded in the horizontal. I turned it with iphoto and saved that. So, what you are telling me, though I did save it, the computer still sees it horizontal?
By the way, that speaker is of a set I sold. More about that later.
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
Yes, when you tell it to turn, it simply puts a tag in there to remember to do it the next time you open it on your computer. Since there is no standard for that, this software doesn't know about it and shows it as it was shot in camera (i.e. 90-degrees rotated).
Gregadd
1,790
1,850
Metro DC
When I try to upload pictures from my computer as an attachment they end being way too large. No complaints otherwise.
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
Can you do attachments on responses to PM's? If so, I could not find anything when I selected Advanced.
Yes you can. It is no different than posting a message here. If you can't find the icon, use then your image URL and then .
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
Native images from cameras and such are extremely large relative to the size you want to use on the forum. Before uploading, use the paint program that came with your operating system and resize it down. Set the horizontal size to 1024 and leave the other dimension blank for the paint program to fill in based on the aspect ratio of the original image. Then save and upload.
