Best SPL Meter app for iPhone ?
jazdoc
3,328
737
1,700
Bellevue
I use Decibal 10th because it's free...
Soundproof
429
1
Oslo, Norway
Get the MicW i436 measurement microphone for iPhone/iPad, while you're at it.
The Studio Six Digital suite is very good.
GaryProtein
2,542
31
385
NY
The JL Audio free SPL app is way off .....
You Bet! I have the "upgraded" version of the JL apps and it is also a total piece of crap. IT'S A TOY, doesn't work worth a damn.
I can go into the quietest closet in my house, hold the iPhone between a rack full of suits and sport jackets, turn off the main circuit breakers in the house, hold my breath and it still registers 40-50 dB. What a waste. I should get my money back.
There is no way any of those apps can even be imagined to replace a real measuring device of any kind.
A.wayne
1,289
2
Front Row Center
Tried Decibel 10th it appears worfully inadequte for bass frequencies , actually a fault of the Iphone more so software IMO.
I'm going to drag my LMS system home and measure the room to see how far off the Iphone really is , it does appear pathetic in the bass regions for sure ....
Soundproof
429
1
Oslo, Norway
Check out Faber Acoustical on the app-store if you want a precision tool.
Soundproof
429
1
Oslo, Norway
The problem maybe the jack of all trades master of none Iphone, not necessarily the apps ....:)
With a microphone attached, you get a very reliable measuring instrument. Several of these app's are calibrated for specific mic's.
Such as this one:
The Faber app's work on the iPad and iPhone. The iPad is used as an instrument emulator for a variety of critical fields. Both iPhone and iPad have computers onboard, and can process properly. So you basically have a Garbage-In/Garbage-Out situation, which can be improved by using an external microphone in this case (as well as a stand, if you want to be accurate.)
Bill Hart
2,684
174
1,150
Maybe you have LOUD suits.
GaryProtein
2,542
31
385
NY
A.wayne
1,289
2
Front Row Center
Such as this one:
Yes .. This makes more sense and i can see where this external mic and file would be favorable.........
http://www.fullcompass.com/product/405975.html
