Dust on records
sombunya
133
8
325
Interesting.
I don't have an expensive cleaning machine but in the last few years I play nearly new or very slightly used records. Dust is still an issue in my house though.
I use the Alsop Orbitrac because I don't lke using the TT motor to spin the platter while I'm brushing or dusting. The carbon fiber brush I use:
always seems to pick up a little more. The pic doesn't show it but there's a small ground wire that runs from the base of the brush/arm stand to a good ground, fwiw.
I also have a Zerostat, but it's hard to tell if it's doing anything, and I really haven't seen any good instructions on exactly how it should be used. Maybe I'll start investingating that device next.
Gregadd
1,774
1,850
Metro DC
IIRC after cleaning point the Zerostat at a 45 degree angle about 10 inches above the record. Slowly squeeze the trigger. Point it away from record before releasing. Repeat.
sombunya
133
8
325
IIRC after cleaning point the Zerostat at a 45 degree angle about 10 inches above the record. Slowly squeeze the trigger, Point it away fromm record before releasing. Repeat.
That is somewhat how I remember, except point it straight on. I'll have to try it out soon.
Thank you.
kach22i
Apr 21, 2010
1,591
210
1,635
Ann Arbor, Michigan
www.kachadoorian.com
I use a Hunt carbon fiber brush for a quick dust cleaning.
I have this battery LED book reading light with clip and gooseneck next to my turntable and it allows me to see everything when the lights are low.
I feel the older AudioQuest and ProJect carbon fiber brushes allow debris to rolls off, and the Hunt is flat.
For a laugh, the heck is wrong with the turntable in this video?
Is it drunk?
sombunya
133
8
325
I'm in a gross minority that won't buy a quality TT that doesn't have a hinged dustcover. No way, no how. No hinged dustcover, no sale. I live with three cats, a dog, two children and a wife, all of whom have a hell of a lot more hair than me.
Felix
Hinged dust covers are nice and I consider them essential. When I play a record they are open. I never, ever, play a record with the cover closed.
