Evolution Acoustics MM3
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
www.pugetsoundstudios.com
Thought I'd post here first before putting on A-gon....
Speakers in perfect cond. Approx 2.5yr. old. Buyer will need to arrange shipping.
rbbert
3,820
239
1,000
Reno, NV
Just after you got them dialed in! What's replacing them, please?
rbbert
3,820
239
1,000
Reno, NV
JackD201
1,429
1,820
Manila, Philippines
Was the tweeter height ever an issue given that you have to work with a console between you and your monitors Bruce?
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
The center of the tweeter is 37" and the lowest my chair will go would put my ear at 44"
Is there any particular weakness in the MM3 are you trying to address, or do you just want to try something new?
I'm an audiophile!! I want that last .5% Plus, it's always cool to get new toys!!
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
Sure, but I am just wondering do you know which 0.5% is missing, and are you specifically trying to address that deficiency with a new speaker. If you buy another great speaker randomly the chips may fall either way, and your could end up with +/- 0.5%, and end up at 100% or 99%.
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
I guess Mike L. is doing the same thing!! ;)
audioguy
73
1,635
An audiophile at 100%? Never gonna happen. ;)
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
Not quite. Mike is buying a a better version of what he had before, so the risk of it being a lateral move or a step back is close to zero. However, you're getting an entirely new speaker, which could work out either way.
By the way, the one speaker I heard that blew me away was the MBL 101e. Probably not very suitable for a studio application. Is this on your shortlist?
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
Not quite. Mike is buying a a better version of what he had before, so the risk of it being a lateral move or a step back is close to zero.?
I don't think so. No one has actually heard a stereo pair of MM7's in a properly set up room, so at best, it's a crap shoot.
Yes, MBL is in contention as well. I'm open to all.
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
Good point, I was thinking that myself, but since I know little about rooms and speakers did not want to engage in speculation outside of my area of expertise. If I made such a suggestion on AVS forum I would be ripped to pieces.
Mike Lavigne
Apr 25, 2010
12,596
11,689
4,410
actually there is a set of MM7's (the first one's built) in the 'mountain region' in a room that is purpose built and a similar size to mine that Kevin already traveled to to set up.
the word is that they sounded phenominal.
same electronics as mine, except no analog sources.
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
See, there you go. "A" set with hearsay evidence. I wouldn't put $10 on odds like that. You're a gambling man Mike!
audioguy
73
1,635
Sure, go to the blue note, order a pitcher of margarita, sit back and listen.
Shoot. If I drank a pitcher of margaritas in my own listening room, I would be at 100%. Reminds me of an old adage when I was single, drank a lot, and much, much younger and was "out on the town" looking for eligible (?) women: "you can drink 'em pretty but you can't drink 'em thin". I think some portion of that somehow applies to audio as well :D
