MM3 - please describe the sound
Gregadd
1,789
1,850
Metro DC
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
I've been contemplating putting my pair up for sale.
Interesting. If you're patient you may indeed get $35. Mike's are a bit older than yours. What would you replace them with? Since you are apperently toying with the idea of placing some subs in the room to smooth out the bass response probably something that does not need to go down to 10 Hz, as your low bass would be taken care off through subs. Just speculating of course. The one speaker I would have considered is the TAD (purely based on reputation).
4,700
JackD201
1,428
1,820
Manila, Philippines
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
Wait! There's a vaccine??!!
Is it Stereophile Class-A rated?
There is no vaccine. It is an obsessive compulsive disorder. Your best bet is counceling or a 12 step recovery program. However, if you an afford it, your best bet is to just get your upgrade fix. That is what I do too.
4,700
My room's not big enough for them! ;)
I like the route that Christian went though!!
The ones ending in 2 or those ending in F? ;)
