Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Target Curves
  1. #21
    WBF Founding Member audioguy's Avatar
    Join Date
    Apr 2010
    Location
    Roswell, GA
    Posts
    1,735
    Ken: Is there a way with the TacT software to adjust target curves via some table manipulation approach instead of on the actual curve itself? It sure would be easier to get more granular settings.
    SigTech had tables we could manipulate which came in very handy.
    Thanks...
    Chuck
    Life is uncertain. Eat dessert first
  2. #22
    WBF Founding Member RUR's Avatar
    Join Date
    Apr 2010
    Location
    SoCal
    Posts
    650
    Not that I'm aware of, Chuck. There is tabular data for the Parametric EQ, accessable via the front panel of the preamp using the remote. Nothing I can find for the RCS, either via front panel or PC GUI.
    The software's so arcane I wouldn't be surprised to find out that it's buried somewhere, though.
  3. #23
    Addicted to Best! Phelonious Ponk's Avatar
    Join Date
    Jun 2010
    Posts
    6,156
    Tim, a couple of other observations now that I'm properly caffeinated... The TacT will provide adjustments as small as 0.8Hz and 0.1 dB. How much more granular are you seeking?
    More granular than I currently have. Yes, 0.1 db would do.
    P
  4. #24
    Join Date
    Apr 2010
    Location
    Roswell, GA
    Posts
    1,735
    Quote Originally Posted by RUR View Post
    You could be right. I don't know how I would design it any better given the massive functionality that it provides ---- but if you right click on the upper left portion of the screen, cross both of your legs, hold your right thumb at 45 degrees and yell "zowie" simultaneously, you might find it !!
    Lots of hidden stuff.
Similar Threads
  1. Equalization Curves and Polarity
    By astrotoy in forum Phonostages
    Last Post: 03-20-2012, 07:06 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
