Page 22 of 22 FirstFirst ... 1213141516171819202122
Results 211 to 217 of 217
Thread: What do you use for vibration isolation?
  1. #211
    [Industry Expert] ddk's Avatar
    Join Date
    May 2013
    Location
    Utah
    Posts
    2,667
    Quote Originally Posted by Ron Resnick View Post
    Why do you like the idea of thin layers of lead and steel rather than a thick slab of lead between two sheets of steel?
    and how do we know for sure that lead is a good vibration absorber?
    Ron, what we discussed with lead or steel is mass loading the rack to control vibration nothing to do with vibration absorption qualities of these materials. There's also Resonance control that one needs to think about, what and how you introduce other materials is based on the equipment sitting on this steel shelf. There's absolutely no reason to introduce layer or layers of lead into a this slab of steel, what is it supposed to accomplish?
    david
    Audio Industry Affiliate:Lamm, Ortofon, ZYX, Keith Monks, Audio Desk, Jensen Transformers, Pheonix Engineering.
    Specialty & Unique Offerings: Vintage horn speakers, Vintage and Modern Turntables, Analog Accessories.
    System 1: Horns+Tubes+Vinyl and digital too- Listening Room 1
    System 2: Horns+Tubes+Vinyl and digital too- Listening Room 2- Near field setup
  2. #212
    VIP/Donor [VIP/Donor] microstrip's Avatar
    Join Date
    May 2010
    Location
    Posts
    12,488
    Quote Originally Posted by ddk View Post
    david
    Good points. My multilayer dual material approach is mostly due to the fact that I can can have a local firm to cut layers up to a maximum thickness of around 3/8" and I want to have some vibration absorption in the table, as I am going to put it on Fabreeka pneumatic insulators - my turntables do not have any suspension. Remember that lead sheet makes an ideal sound barrier, it has excellent mechanical vibration absorption qualities.
    My approach is intuitive, I am not an expert in vibration control!
    Attached Images Attached Images
    Under construction around the DCS Vivaldi 2.0 stack and a pair of Wilson XLF's : Forsell Air Force One, ARC Phono 2SE, cj GAT, LP275m's , TA OPUS MM2 IC's and sp, TA XL digital, TA XL gen V power cables and CenterStage footers ...
  3. #213
    Site Founder And Administrator Ron Resnick's Avatar
    Join Date
    Jan 2015
    Location
    Posts
    3,467
    David, at 340 pounds I think my Frankenstein platform also satisfies a mass-loading objective.
    If, in fact, lead absorbs vibrations why not also have the table top dampen vibrations traveling through the table top from either direction?
    Mono and Stereo - Senior Contributing Reviewer
    turntable: American Sound AS-2000; tonearms: SME 3012R, Schröder LT
    cartridges: ZYX UNIverse Premium X-SB2, Benz-Micro LP S; tape: Studer A820 Mk II
    phono stage: Aesthetix Io Eclipse; line stage: Aesthetix Callisto Eclipse
    amplifiers: Alieno LTD 250, AM Audio 833S Ultima; speakers: Gryphon Pendragons
    cables: MasterBuilt Ultra or Cardas Clear Beyond (TBD); power: Benjamin Electric subpanel; Torus AVR60BAL; JPS in-wall wire; Furutech NCF outlets; room: 20' wide X 25' long X 15' tall; treatment: ASC Tube Traps and Tower Slims; tweaks: Herzan/Taiko Tana, Shakti Stones, Shun Mooks
  4. #214
    Join Date
    May 2013
    Location
    Utah
    Posts
    2,667
    Your rack isn't the problem it's the top shelf that we wanted to improve.
    Lead doesn't absorb vibration it's used for mass damping like steel. Because of it's density lead has more mass than steel so a sheet, bar or lead shot will weigh more but it doesn't matter when you're talking solid 3/4" steel plate.
    david
  5. #215
    Join Date
    May 2013
    Location
    Utah
    Posts
    2,667
    Quote Originally Posted by microstrip View Post
    I like the the Fabreeka insulators, I use thick o-rings under the steel shelves. 1/2" - 3/4" is pretty inert you can use it with or without the lead sheets.
    david
  6. #216
    Addicted to Best!
    Join Date
    Dec 2010
    Posts
    10,102
    david
    Yes, in our case, we tried to find lead due to its significantly greater density (more compact, same weight) but no one will sell it here so we used brass which is the denser of the commonly available metals. It rings like any other metal, but on top of elastomers from HRS, or damping plates from Artesania, the ringing stops, and otherwise it works incredibly well to mass dampen amps, source equipment and especially the Velodyne...keeping away a good amount of vibration.
    Speaker Wilson X1/SLAMMS / Velodyne DD18+
    Source Zanden 4Box Digital
    Amp CJ GAT 2 / Gryphon Colosseum
    Cable SC/IC / PC TA Opus Gen5/MM2 / PAD25th/Sablon GCUber
    Isolation Sandwiches Under: HRS/Stillpoints/Auralex Top: HRS/Artesania/Entreq/EAT/90kg Mass
    Power/Ground/Shield 7 x 16A Furutech / Burmester948+NordostQX4 / Tripoint TroySig+Thor / Entreq Atlantis/Receivus/Everest/Wrap
    Room/Tube Stillpoints Apertures / Amperex Mullard
    Headphone Sennheiser HD650 / Arcam rHead/ApogeeGroove
  7. #217
    Hello Happy New Year,
    Three Feets from Fabreeka you need min. 95kg for 3-4 Hz Isolation...
    The Best Way is a Schiefer Slate no Metal or Layers of this it sounds no good.
    I have a 2 inch thick Slate 70cm x 55cm x 5,5cm weight 58kg.
    My Feets from here..you need 80% from Mass Loading for a good Setup
    http://cplusw.de/de/din_luftfeder.php
    http://cplusw.de/zoom.php?datei=reso...ftfeder_gr.jpg
    Best Regards,
    Stephan
    Customade Thorens 124 with Air Suspension
    TW-Acustic 10.5/Zyx Airy3x DIY 13"Arm Ortofon Vienna
    Phono DIY Tube Amp ECC808 SUT Silvercore 1:20
    Digital Foobar Kernelstreaming Aqvox IFI Purifer Low Noise USB Sonic Frontiers SFD 1 DAC
    for HiRes Files Soekris Dac
    Line Pre /Silvaweld SWC 450
    Power Amps/ Raphael Audio EL34 /Yamaha P3500S
    Speakersystem/Open Baffle 15"Coax Dipol Horndriver with active 15"
    Bass (30Hz-19Khz +-2dB) Signal Cable Pure Silver
Similar Threads
  1. Turntable Isolation
    By MylesBAstor in forum Isolation Devices/ Stands
    Last Post: 02-04-2018, 08:24 AM
  2. Best Isolation Systems for Amps
    By brianherlihy in forum Audio Tweaks Forum
    Last Post: 08-01-2016, 05:53 PM
  3. Isolation materials
    By ack in forum Isolation Devices/ Stands
    Last Post: 07-17-2016, 04:34 PM
  4. Vibration, isolation and electronics...
    By Phelonious Ponk in forum General Audio Forum
    Last Post: 07-11-2011, 03:11 PM
  5. Vibration isolation for my VPI Aries 3
    Last Post: 05-15-2010, 06:02 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
