I was asking because I measured the left side t 140 degrees and the right at 115 degrees F. Is this normal?
Wow excellent room Rocco! Great to see your new custom built room come into shape
Thank you very much sujay. I sent an e-mail to Burmester, no reply yet.Nice set up. I think it is to do with bias current adjustment. You will need a technician to adjust the bias to the reference specs. I would suggest you call Burmester directly and they will help you out if your dealer isn’t cooperative.
Ciao Dear Rocco
Sure is better post here our system than on stupid Italian forum
I wish that other brands would pay more attention to vibration control. I use the Arya RevOpod footers with the 911 and find them really beneficial. I also notice that the 911 chassis is "open" with narrow slits (2-3mm) at each corner. This may help the 911 stay cool even when playing loudly.Hi, while I’m not a techie either, what I understand is that the foam is indeed used for damping the caps. The rest I won’t be able to help you with. As an aside, I have heard another identical set up with the 911 stereo driving the Altria’s and they sounded amazing
