Stand UP Vacuums
Fred
296
5
365
Covington, LA
What kind do you use. I finally broke down and bought a Dyson DC-41 Animal. What a difference it makes in cleaning the carpet. We own one cat and I can't believe how much hair that little urchin has put in my carpet. I find the Dyson to be much quieter than previous vacuums and the suction power is superb. The ball make manuevering sublime and the transistion from carpet to hard surfaces is nothing short of fantastic.
If you own stock in a broom company my advice would be to liquidate that position. ;)
Ronm1
1,745
4
wtOMitMutb NH
We have used a Kirby G4 for over 30 yrs now. Still works very well on carpets and makes a transition to floors quite easy, but can be a PITA for anything else. It is by no means quiet.
Keith_W
1,024
95
970
Melbourne, Australia
www.whatsbestforum.com
I think stand up vacuums are much better than the other type. Because they have beaters and put more weight on carpet, they seem to clean carpet more effectively.
I have 3 vacuums at home - an upright Dyson, a handheld Dyson, and a robot vac cleaner :)
MylesBAstor
81
1,725
New York City
I agree on the Dyson. Couldn't believe how much fur it removed from the carpet :(
You do need to keep the Dyson though immaculately clean to ensure it working properly. That included the rotor that gets easily clogged, and dirt trap that fills quickly (including also the "foam" filter that needs washing on a regular basis).
Dimfer
622
181
1,605
Canada
we're happily living with a Shark Navigator for 2 yrs now... much better than our previous hepa filter vacuum cleaner, we were surprised how much dirt it picked up from our carpet the first time we used it... build quality is not as good as Dyson, but is not priced as expensive as Dyson either.
my wife bought it after seeing this infomercial
she's happy with it, and has recommended it to her mom and 2 sisters.
yes, it sucks :cool:
