Wilson Alexandria Speakers...Why not a bi-amp solution from Wilson for this chassis?
LL21
14,423
2,516
1,448
Very cool thanks! The MAXX 3 is not as heinous as the MAXX 1 or 2 in terms of the impedance spectrum. They only dip down to a minimum value of 3.4 ohms rather than 2.25 ohms for the MAXX 2.
I assume you feed the unadulterated signal to your X1 and a separate output from your pre to the Velodyne?
Cheers.
Absolutely...full range to X1 and full range to the Velodyne which then is cut off above 40hz. The CJ GAT 2 has 2 independent sets of RCA outs which works really well. As for Maxx 3 and SETs, you might still need to be careful. Not sure what happens at 3ohms...but even the mighty KR DXL (the latest version is 200 watts of Class A SET power) recommends 4ohm minimum.
