I get imaging. It happens in all directions and is primarily a function the recording and the mix -- the engineer pans the stereo image of the elements of sound, placing them in the L to R plane. He uses mic choices, placement, studio ambience, processing and, mostly, volume in the mix, creating a sense of depth. Assuming - and this is a huge assumption these days - that the mastering engineer doesn't throw it all away at that stage, and all of this is done really well, you should have a recording with a reasonably good illusion of space, even if it was all recorded in a small studio. Playback electronics can, in my view, only subtract from the recording. If you switch one relatively transparent (another "what is" if there ever was one) DAC for another and hear a dramatic expansion of the sound stage, enjoy that, but it's expectation bias. And if, in a perfect theoretical world, your electronics get out of the way, the engineer's creation of space should reach your speaker terminals.
Then all hell breaks loose and all bets are off.
So is the difference between imaging and sound stage something that happens in the interaction between our speakers and our rooms? Is it entirely a creation of our systems, dependent upon, but not a part of the recording itself?
Enquiring minds want to know....
Tim
Tim
