Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 69
Thread: Jplay : Wow
  1. #41
    Member Sponsor Addicted to Best!
    Join Date
    Feb 2012
    Location
    Ireland
    Posts
    3,426
    Quote Originally Posted by Vincent Kars View Post
    One thing is obvious, sending a signal to a DAC is done using a 100% analog wave.
    But can software affect this wave?
    An explanation might be the way the data is processed.
    Is it done in bursts or is it throttled. The burst might induce periodic jitter, the throttle a constant jitter level.
    However, if this is true I want to see measurements e.g the eye pattern when playing software A or software B.
    Personally I don’t mind any claim about improved sound quality by any piece of software but if it does something I like to see at least a measurable difference.
    One issue with USB is that it sends regular bursts of info like the start of frame packet - "The SOF packet consisting of an 11-bit frame number is sent by the host every 1ms 500ns on a full speed bus or every 125 s 0.0625 s on a high speed bus". If the timing of this shifts or is variable, this could elicit a different & variable reaction from the USB receiver & translate into a different & varying jitter or noise spectrum. Making the PC end as solid & stable as possible without undue processing could be one factor in ameliorating this variation. It might not be the low level of jitter that we notice but the variation in jitter - that's one reason why I say that the measurements we currently run seem not to be capable of picking up these issues or we are not directing them to the correct target for measuring.
    Manufacturer digital products www.Ciunas.biz
    "The greatest obstacle to discovery is not ignorance it is the illusion of knowledge." - Daniel J. Boorstin.
  2. #42
    Computer Audio [Technical Expert]
    Join Date
    Jul 2010
    Posts
    860
    Quote Originally Posted by jkeny View Post
    All these things need to be teased out to have a full grasp of at least one aspect of computer audio. We are at the discovery phase at the moment so guesses & claims & denials, etc are par for the course as witnessed here.
    +100
  3. #43
    Junior Member
    Join Date
    Jan 2012
    Location
    Standish, Maine
    Posts
    4
    This is my first post as well.
    I'm currently using JRiver v.16 and found it superior to Media Monkey (both for sound and as a database manager) on my Goodwin's Silent Server. Tried to use JPlay with it and it was VERY problematic. My question for you is whether you tried JRiver by itself before you added JPlay and whether there was a significant improvement.
  4. #44
    Banned
    Join Date
    Apr 2010
    Location
    Seattle, WA
    Posts
    16,044
    Look forward to any results you might present but I don't know if you will find it in jitter levels? It's true that if there is an audible difference then it should be seen in the analogue output but what measurement do we use & what level are we viewing down to. I contend that FFT analysis may not be the correct test method as it uses multiple samples to average over time - will it for instance show the time-smearing of different digital filters? The focus in audio measurement still is rooted in the frequency domain (except when speakers are being measured) - I believe this focus has to change & perhaps new measurements introduced.
    My analyzer is "dual domain" so can measure in analog domain in addition to FFT based digital.
  5. #45
    Join Date
    Feb 2012
    Location
    Ireland
    Posts
    3,426
    Quote Originally Posted by amirm View Post
    OK, will it show noise modulation? I'm asking this in complete innocence & without any judgement. I f you can uncover differences I would be interested.
  6. #46
    Quote Originally Posted by doclarry View Post
    I started with Media Monkey, then switched to JRiver v.17, then added JPLAY for JRiver. Each step was an improvement. The step up to JPLAY was bigger than the switch from Media Monkey to JRiver. I believe you need to upgrade to JRiver v.17 before adding JPLAY.
  7. #47
    Join Date
    Feb 2012
    Location
    Ireland
    Posts
    3,426
    Quote Originally Posted by rhbblb1 View Post
    Or you could try running Jplay in standalone mode to hear what it sounds like - JPlaymini & then use whatever front end suits your needs - Foobar or JRiver or MP3Toys or ......
  8. #48
    This information is suspect. rhbblb signed up to post about jplay and seven of eight posts are about jplay.
    JRiver has asked jplay to remove all references to JRiver from their site. So far, they have not done so.
  9. #49
    Quote Originally Posted by jriver View Post
    Mr. J River,
    Get a life. The last time I looked this was a hobby. If you think I signed up to WBF to post about JPLAY you are sadly mistaken. If you believe that it is suspect that JRiver is superior to Media Monkey, so be it. nuff said.
  10. #50
    Site Founder And Administrator Steve Williams's Avatar
    Join Date
    Mar 2010
    Location
    Coto De Caza, California on the 13th fairway of the south golf course
    Posts
    26,381
    Really. Enough said
    aka oneobgyn
    There's ALWAYS another Steve Williams BUT there's only "oneobgyn"
    USA Dealer of Center Stage Feet and owner of PitchPerfect Sound (www.pitchperfectsound.com)
    Dealer Lamm Electronics
    My System
Similar Threads
  1. A Solution to Wow/Flutter?
    By Bruce B in forum The Pro-Audiophile By Bruce Brown
    Last Post: 10-24-2012, 09:54 PM
  2. 2X DSD streaming from my server thru the Playback Designs MPS-5......WOW!!!
    By Mike Lavigne in forum Computer Based Music Server Forum
    Last Post: 10-19-2012, 09:55 AM
  3. Wow
    By Steve Williams in forum Off Topic Forum-Anything Goes
    Last Post: 12-01-2011, 05:17 PM
  4. Today picture in Telegraph; Wow never appreciated size of crocodiles
    By Orb in forum Off Topic Forum-Anything Goes
    Last Post: 07-14-2011, 03:48 AM
  5. WoW! Is this Reporter lucky, Evan Longoria has amazing catch
    By RogerD in forum Off Topic Forum-Anything Goes
    Last Post: 05-14-2011, 02:34 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
