Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Gaps when "quoting"?
  1. #21
    WBF Founding Member John72953's Avatar
    Join Date
    May 2010
    Location
    Oakville, ON
    Posts
    4,428
    Quote Originally Posted by fas42 View Post
    Don't worry, John, browsers can be a nightmare. I like, or am very used to, Firefox but over the last month I've lost all the buttons when I do an Advanced Reply. So can't add proper emoticons, etc. I SHOULD know how to sort out software, but I've given up trying to fix this annoyance ...
    Frank
    I'm not really worried Frank! I can always use Firefox for use here. And yeah..its an annoyance more than anything.
    I love the smell of vinyl in the morning!
    John Adrian Spijkers - "Live Life! Leave A Legacy!"
  2. #22
    Site Founder And Administrator amirm's Avatar
    Join Date
    Apr 2010
    Location
    Seattle, WA
    Posts
    7,395
    Oh, I figured it out. It is an IE issue. Hit F12 again. Then under the "Browser Mode" select plain "Internet Explorer 9" *NOT* the one with compatibility mode.
    Amir
    Founder, Madrona Digital Audio, Video, Home Automation
    Contributing Editor, Widescreen Review Magazine
  3. #23
    Join Date
    May 2010
    Location
    Oakville, ON
    Posts
    4,428
    Quote Originally Posted by amirm View Post
    Success!
    Amir...thank you!
  4. #24
    Join Date
    Apr 2010
    Location
    Seattle, WA
    Posts
    7,395
    You are welcome. I think what happened is that you had changed IE's compatibility mode sometime before and hence seeing it all of a sudden.
    Amir
  5. #25
    Join Date
    May 2010
    Location
    Oakville, ON
    Posts
    4,428
    I did. I was having some issues with my keyboard...started moving pages up and down in rapid succession and then downsized (reduced zoom level) the screen display to about 25%. Try zooming down to 25% and you'll see how small the text is. It was then that I started to look for solutions, and remember clicking on that setting. Long story short, I changed the zoom level, but never adjusted the comp mode setting (slipped my mind entirely).
  6. #26
    Site Founder And Administrator Steve Williams's Avatar
    Join Date
    Mar 2010
    Location
    Coto De Caza, California on the 5th fairway
    Posts
    13,668
    Quote Originally Posted by John72953 View Post
    Success!
    Amir...thank you!
    Isn't he a genius John
    Amir has solved countless problems for me.
    aka oneobgyn
    There's ALWAYS another Steve Williams BUT there's only "oneobgyn"
    Industry Affiliation........Lamm Dealer
  7. #27
    Join Date
    May 2010
    Location
    Oakville, ON
    Posts
    4,428
    Quote Originally Posted by Steve Williams View Post
    Good choice of a partner there Steve!
  8. #28
    Join Date
    May 2010
    Location
    Oakville, ON
    Posts
    4,428
    Amir
    It seems like the problem has not gone away. Everytime I go back onto the site it reverts to Compatibility View as the default. I now have to hit F12 every time and select my browser (IE9). Suggestions? Ideas?
  9. #29
    WBF Technical Expert
    Join Date
    Jun 2010
    Location
    Monument, CO
    Posts
    2,546
    You might want to check under the Tools menu button at the upper right (assuming IE9 is similar to IE8), then select Compatibility View Settings and make sure WBF wasn't added to the list... Beyond that, I think you can check the advanced options/settings to make sure it isn't on all the time, or automatic for sites it thinks need it.
    HTH - Don
    Don Herman
    "After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
  10. #30
    Join Date
    May 2010
    Location
    Oakville, ON
    Posts
    4,428
    Thanks Don, but IE9 works slightly different as I didn't see that option. Anyway I went back to the IE9 original default settings, and it seems to have solved the problem. Here's hoping!
Similar Threads
  1. "Fast" and "slow" subwoofers: can we put them to bed?
    By twelti in forum Todd Welti Discusses Subwoofers In Rooms
    Last Post: 07-20-2011, 05:14 PM
  2. What are "Bits" and "Bytes", and why do you care?
    By Scott Borduin in forum Scott Borduin and Amir Majidimehr On Software and Hardware
    Last Post: 03-22-2011, 08:23 AM
  3. Replies: 6
    Last Post: 02-15-2011, 12:19 PM
  4. Do you want "in the room" or "in the recording" for your sound?
    By amirm in forum General Audio Discussions
    Last Post: 01-04-2011, 04:56 AM
  5. Replies: 11
    Last Post: 07-25-2010, 07:52 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
