Friend's A80VU left channel blasted with smoke, he asked me not to fix it but modify it with tube like I did in A80RC, and also he like to use as play back only. the audio electronic between this two models are not the same only in same transport, VU separate the out put into other card from repro card and add SYNC card too, also select switch for NAB and CCIR, both build in, some ICs use to replace SS you can see in later model A810 in similar design with more ICs to use in replacing, IMO still RC sound better than VU. anyway I will do in the same way of what I did in RC, keep the both sections ( EQ & control ) in stock, just convert the out put into tube and transformer, because no recording use, so I took out most things from the case, only keep the repro pre amp and power supply ,command card in there, looking for enough space for tube and transformer and 6 new bigger size coupling cap, also I can't keep the meter and play back no meter needs just for style only, without meter connect is better for out put sound quality, there are two version of repro pre amp card, 1080.604 is for 10mH low out put head it with a 1 to 10 step up in put transformer, the other one is 1081.652 without in put transformer but for 200mH head, this one is the first one, my friend like to have a silver wound for it but Studer will not tell the the impedance of it, friendly Jack Elliano made me a sample in copper with multi taps first, let me see which is the best sounding tap and then to silver for saving money. or in future option replace a butterfly head (200mH) into recording head and switch by pass the step up, that can ABX of two different heads, pictures show changed parts and the looking before and after
tony ma
tony ma
