Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
Thread: Computer Audio: Is isolation as good as optimization?
  1. #21
    Quote Originally Posted by Vincent Kars View Post
    You might use Wi-Fi or Ethernet (also galvanic isolated) but you need a processor to do all the networking.
    Might be a small one (SqueezeTouch) but it is a kind of mini PC.
    So the question arise how to isolate the DAC from this computer!
    Of course. I didn't think of that. It could, however, be a very simple, dedicated computer with minimal processes, no HD, no fan...pretty much with the dedicated minimized/optimized computer server people go for, no?
    Tim
    In high-end audio, you can't even fight an opinion with the facts.
  2. #22
    Addicted To Best
    Join Date
    Jan 2011
    Location
    NSW Australia
    Posts
    3,973
    Quote Originally Posted by Phelonious Ponk View Post
    How about wireless? An obvious advantage is isolation. What are the drawbacks?
    Tim
    Depending on everything, you could have some radio frequency, RF, interference degrading the sound. As an example, I had to do a lot of work on reducing the impact of this: even now there are still "problems", but it's manageable.
    Fank
  3. #23
    Computer Audio [Technical Expert]
    Join Date
    Jul 2010
    Posts
    860
    Yes, like the Squeeze.
    500 MHz ARM, no fan, no HD, no moving parts at all
    But hardcore hackers like John Swenson hacked it to do async USB.
    BTW: it took a while before I understood too that the protocol only is not the message.
    Clever guys like the ones at Devialet now advertise their network connection as Asynchronous!
  4. #24
    Ok, now give me the long version of that, and talk real slow.
    Tim
  5. #25
    Join Date
    Jul 2010
    Posts
    860
    Take SPDIF
    The sender sends the data, the receiver use the send rate to construct the sample rate.
    Obvious the DAC is slaved to the sender.
    Adaptive USB: the DAC construct the sample rate using the amount of data generated by the sender.
    Asynchronous USB: the DAC is told to run at a certain speed e.g. 96 kHz and regulates the amount of data send.
    Obvious the DAC is the master, it can run on a fixed speed, zero input jitter by design.
    Conclusion: an asynchronous protocol is the way to go.
    Wi-Fi or Ethernet are asynchronous by design.
    Conclusion: this protocols are asynchronous so do as well.
    A little experiment.
    Play a song on a PC (sorry no OSX here) from a HD
    Play the same song from an external HD
    Play the same song from a NAS
    Play the same song from another PC in the network using DLNA (sorry no Airplay here)
    All of the time the protocols are asynchronous but you are using the same audio device e.g. the onboard audio.
    In these examples the protocol is not relevant. The configuration is totally different but in the end you are simply reading data and store this in a buffer in memory.
    We are not feeding a DAC using these protocols but reading data to process.
    If we talk isolation of a DAC on protocol level it is not about the method (protocol) used to read the data but about the protocol we use to feed the DAC directly.
    It is not about how to get our audio files into a CPU but about how to get the audio out of a CPU with minimal jitter.
  6. #26
    Addicted To Best
    Join Date
    Jan 2011
    Location
    NSW Australia
    Posts
    3,973
    I think it's getting a bit messy with the throwing around the word asynchronous in these different situations. Another way of explaining things would be as follows:
    A DAC needs a good, "clean" clock to deliver good results. Which means that it beats with an absolutely steady rhythm, has to have a perfect "heartbeat". Now every DAC has a clock sitting right next to it, whether it's a crystal or a phase locked loop, PLL, or something else, it's still a clock. Some people may dispute this, but as far as the electronics are concerned it is a clock.
    Now, some of these clocks are set up to march to their own time, they decide how fast they're going, always. Others, have a heartbeat that's bendable, or flexible, they can be told to slightly speed up or slightly slow down, and this is done so many times a second. This is how most of digital works, when sending the musical data from something to the DAC circuitry; the component sending the data out is doing so at a rate, or clock, that suits itself, not the DAC. And the DAC clock has to follow this, otherwise the audio can "glitch". Now, if the heartbeat is constantly being told to speed up and slow down, at a ridiculous rate then it is pretty intuitively obvious this is not a good situation, "jitter" is in the air. So the aim is always to keep the heartbeat as steady as possible, only nudge it one way or the other when you absolutely have to, or never at all if possible. Which gets back to the first version of the clock, the "ideal".
    The way to keep the stress, or need, down of constantly fiddling with the DAC clock's speed, heartbeat, is to have a buffer, a reservoir of data that the DAC can suck out of, at a pace that suits it: the best thing is to have a very, very large dump of this data, so matter how out of kilter the rate of filling up, and emptying of the buffer is, there is never an awkward moment when it's full, or empty. And this technique has been used, successfully to get good audio: it's equivalent to having a DAC clock which always decides its own heartbeat, not something else.
    What's left is deciding what controls the rate of filling up this buffer: the emptying is never a problem, that's always decided by the DAC clock, which is just trying to run as steadily as possible, minimum jitter. The best situation is having the DAC clock effectively deciding this, which means the buffer can be very small, and the heartbeat at the DAC can made as stable as possible. This is done when you have the DAC running a second cable back to the transport, asynchronous USB, and in a sense on a wider network. Networks work as a cooperative thing, no-one is pushing around someone else: one device asks for something, or is told something is coming. The rest of the network can choose to ignore this, or respond. The key thing is that there are no guarantees; except in special circumstances. So a DAC, that has to have a buffer that is never empty or full, otherwise audio glitches, needs yet again for that buffer to be big; this is a more complicated dance between whatever is sending the musical data, and what is receiving it. I don't know what all the "protocols" are, which in part decide who is holding the business end of the whip, setting the clock rate, but good engineering is always needed to make sure that firstly the buffer is handled correctly, and secondly that the DAC clock, the crucial heartbeat, is able to run at as steady a pace as possible ...
    Frank
  7. #27
    Banned
    Join Date
    Apr 2010
    Location
    Seattle, WA
    Posts
    16,044
    Tim
    The drawback is that it requires a CPU running an operating system just to receive the bits. Keeping those high-speed signals away from the DAC will be the challenge.
  8. #28
    In my experience improving computer power sources and filtering without isolation if not enough. The common ground between the computer and the audio gear will always transmit significant high-frequency noise. Galvanic isolation eliminates ground loops. Proper implementation can achieve barrier capacitance as low as 20 pF.
    Achieving ground isolation dramatically reduces noise, but this is not the only problem when computers are used as music players.
    Computers are general purpose devices and it is not a trivial task to turn them into audiophile grade gear. There are a number of hardware and software elements in the sound-streaming chain and all of them must be fully transparent. These include the media files, the software player, the OS sound subsystem, the sound driver and the audio interface to the external DAC. All must be bit-perfect and the sum of them must be jitter-free.
    I achieve this by using simple bit-perfect players, proprietary bit-perfect sound drivers, proprietary asynchronous USB interface with error correction, GMRs for galvanic isolation and re-clocking.
    A truly asynchronous interface compensates for the unstable computer timing. Therefore there is no need to try to eliminate background computer processes like disk operations and networking.
    The benefits of this approach are fully realised when high-bit-depth / high-sampling rate media files are used. In my experience the highest degree of realism is achieved when source files are played at their native sample rate and resolution.
    George
  9. #29
    Banned
    Join Date
    Apr 2010
    Location
    Seattle, WA
    Posts
    16,044
    Great post George . It is the right formula.
    We need at some point an objective way to prove it. Folks still spend a lot of energy and money on improving sources even with all the things you (and I) mention.
  10. #30
    VIP/Donor [VIP/Donor] microstrip's Avatar
    Join Date
    May 2010
    Location
    Posts
    13,435
    Quote Originally Posted by exa065 View Post
    (...) Computers are general purpose devices and it is not a trivial task to turn them into audiophile grade gear. There are a number of hardware and software elements in the sound-streaming chain and all of them must be fully transparent. These include the media files, the software player, the OS sound subsystem, the sound driver and the audio interface to the external DAC. All must be bit-perfect and the sum of them must be jitter-free.
    A truly asynchronous interface compensates for the unstable computer timing. Therefore there is no need to try to eliminate background computer processes like disk operations and networking. (...)
    George
    George,
    Here we go again. Can you conclude from your words that a server implemented using, for example, Windows7, Jmriver and direct ASIO drivers playing FLAC native files at native sampling can be "bit non perfect" ?
    What are calling "fully transparent"?
Similar Threads
  1. Wish we could get the hi-res Neil Young Archives for computer audio
    By Randall Smith in forum General Music Discussion Forum
    Last Post: 04-20-2012, 11:31 PM
  2. A Beginner's Guide to Computer Audio
    By Lee in forum Computer Based Music Server Forum
    Last Post: 05-07-2011, 04:58 PM
  3. [WIP] Windows Vista/7 audio platform optimization project
    By Windows X in forum Computer Based Music Server Forum
    Last Post: 05-05-2011, 04:25 PM
  4. Forum Posting: on XBMC Audio/Video interface/server for your computer
    By amirm in forum Computer Based Music Server Forum
    Last Post: 12-25-2010, 05:21 PM
  5. Best retail dealers in computer audio
    By Nicholas Bedworth in forum General Audio Forum
    Last Post: 12-15-2010, 08:54 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
